Turbo manifold fabricators/ I need help
Old Aug 7, 2003 | 10:14 AM
MIKES's Avatar
Default Modified Spark/OBX/Meng manifold need opinions/ braced it already
I just got my Spark racing manifold back from the machine shop. I had them brace the hell out of this manifold. They braced every runner and the wastegate too. They also ported out the wastegate hole to the size of the gasket to prevent boost creep. My question to you is, Should I have expansion slots cut into the flange or drill out the bolt holes a touch bit larger? Here are the pics of what I had done. Let me know what you think. Thers no point in selling this manifold at this point because being that I am Canadain I can't afford to drop more coin and buy something different. The manifold is heavy as **** right now with all this extra metal on it. You won't be able to see the braces once its on the car.
Modified by MIKES at 1:39 PM 8/7/2003
Old Aug 7, 2003 | 10:21 AM
lazerus's Avatar
Default Re: Turbo manifold fabricators/ I need help (MIKES)
drilling the holes slightly larger and using washers should work just fine to take up for expansion. at least it has for me in the past, and of course many others.
Old Aug 7, 2003 | 10:40 AM
Overblown-Teg's Avatar
Something else to try is mounting the downpipe solid so it can't move around.. That will help take some of the weight off the turbo..
Old Aug 7, 2003 | 12:09 PM
MIKES's Avatar
Default Re: (Overblown-Teg)
TTT
Old Aug 7, 2003 | 12:44 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (MIKES)
DAMN, you braced the **** ouit of that manifold. Keep us posted of if it cracks. BTW, i would try to cut expansions slots if i was u.
Old Aug 7, 2003 | 12:58 PM
MIKES's Avatar
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (SIXTYdashONE)
SIXTYdashONE- That was my question, where would you cut the expansion slots? In the bolt holes or inbetween the bolt holes from each cylinder?
Old Aug 7, 2003 | 01:02 PM
legendboy's Avatar
holy overboard batman
Old Aug 7, 2003 | 02:26 PM
1.8T_EG's Avatar
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (legendboy)
... looks sweet... how much did it cost to get braced?... keep us updated...
Old Aug 7, 2003 | 03:24 PM
GSRswapandslow
Guest
Posts: n/a
that actually looks cool as ****....
haha, i'd like braces on top too
Old Aug 7, 2003 | 05:24 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKES &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by MIKES at 1:39 PM 8/7/2003</TD></TR></TABLE>
Hey that looks like what I used to make with Popsickle sticks and throw them against the wall and they all busted apart! Now that's what I call bracing!!!!! Ask Geoff about this, he had made some comments about bracing it causing it to crack more, I could be wrong though. I think the main concern was at the wastegate to the mani though. Good luck.
Old Aug 7, 2003 | 06:37 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (Boostfed)
i hate to say it but i bet it will crack still. maybe not in the places where its braced but at the welds or some other part. good luck!!!
Old Aug 7, 2003 | 06:41 PM
Lamchop0000's Avatar
hmm looks cool but... how about your oil dip stick?
Old Aug 7, 2003 | 06:44 PM
TeStUdO's Avatar
Default Re: (lamchop0000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lamchop0000 &raquo;</TD></TR><TR><TD CLASS="quote">hmm looks cool but... how about your oil dip stick?</TD></TR></TABLE>
thats the least of his problems
Old Aug 7, 2003 | 06:49 PM
HT's Biggest Loser
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">i hate to say it but i bet it will crack still. maybe not in the places where its braced but at the welds or some other part. good luck!!!</TD></TR></TABLE>
Yah, i will back him on this one also. Reason being is because the metal they use to make those manifolds are basically recycled soda cans. Other top quality equal lenght manifolds use a stronger guage metal.
And to answer your question from before, id say cut expansion slots for each runner, and not for the bolt holes. good luck man..
Old Aug 7, 2003 | 07:25 PM
int3gra's Avatar
maxrev ones have expansion slots cut in the middle of the bolt holes, if thats any help.
Old Aug 7, 2003 | 08:15 PM
SiRkid's Avatar
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (int3gra)
Might aswell.
See if you can have it dipped/coated in titanium too
Old Aug 7, 2003 | 08:23 PM
Ray's Avatar
Ray
New User
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (SiRkid)
If you can fabricate a brace to support the turbo and downpipe you should be good.
Old Aug 8, 2003 | 12:31 AM
dmecarboy's Avatar
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (Ray)
Have the same manifold! Been boosting 20psi with SC60 on built gsr for 6 months. No cracks, no problems, no bracing!
Old Aug 8, 2003 | 04:56 AM
MIKES's Avatar
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (dmecarboy)
dmecarboy- whats your setup if you don't mind me asking? Looks like your making good power. Got any pics?
As for my manifold, I am just going to try it out and see what happens. I have some custom brackets being made by my nieghbour for my downpipe. Its going to stop the movement of my exhaust so my turbo doesn't move around a great deal. Its going to have bushings placed in the bracket to absorb some of the shock of just day to day driving. My car is going to the bodyshop for touch ups and they are going to cut out my front bumper for my intercooler. So when I get her back its on. Maybe she will stay together, maybe not. Time will soon tell. Any comments on the expansion slots? Is it worth it yes or no?
Old Aug 8, 2003 | 02:34 PM
dmecarboy's Avatar
I have some pics, but I'm not to sure how to post them yet. Still a rookie here on H-T. When I figure it out, they will be up no doubt!!!
Old Aug 19, 2003 | 12:39 AM
dmecarboy's Avatar
Well manifold has cracked since the last post, #4 right by the flange. Hope yours don't
Old Aug 19, 2003 | 12:40 AM
dmecarboy's Avatar
Old Aug 19, 2003 | 02:24 AM
PureTeg420's Avatar
Old Aug 19, 2003 | 03:32 AM
DaveF's Avatar
edit- just testing my skills to see if i could get the pic to come up.
aftermath. i did get it up! but deleted due to having it up already one post above mine.
Old Aug 20, 2003 | 08:11 PM
dmecarboy's Avatar
Default Re: Modified Spark/OBX/Meng manifold need opinions/ braced it already (2.2Lcivic)
thanks pureteg420, obviously I still dont know what I'm doing!!!
