anti-lock brakes?
IN the front of the car passenger side (next to the Airbox) there will be a pump with hardlines coming out of it.
OR.. your axles will have "TEETH" (like a gear) on them near the end that fits into the HUB (NOT the VERY END, but near the rubber BOOT)
OR
If you stop REALLY hard, you feel the brake pedal vibrate
OR
i doubt you car has abs, but:
-abs equipped cars have all 4 disc brakes, if yours has drums in back its not abs equipped
-abs module located behind passanger side headlight
-if you have the axles out, you can tell by just looking at the hub side of it. abs has litte grooves, non-abs is smooth all around
-brake hard over water if you hear constant clicks abs is activated
