Taillights, guages,instrument light not working
Old Aug 7, 2003 | 08:26 AM
4speed's Avatar
Default Taillights, guages,instrument light not working
Taillights, guages,instrument lights are not working, none of the turn on, does anyone know how i can fix this? I have a 1990 hatch STD
Old Aug 7, 2003 | 08:30 AM
BdoubleU's Avatar
Default Try checking your fuses...
They are located under the steering wheel.
Old Aug 7, 2003 | 08:33 AM
4speed's Avatar
Default Re: Try checking your fuses... (BdoubleU)
its not the fuses, ive already tried that
Old Aug 7, 2003 | 09:43 AM
sleeper4dr's Avatar
Default Re: Try checking your fuses... (4speed)
a combination of things not working like you said is almost certainly related to bad fuses. check them again!! its easy to miss one if you rush.
if you pull the fuses related to the non-working circuits and you know they are good...
then try pulling the fuse and sticking a voltmeter to each of the contacts. is there power and ground at those contacts when you turn on the instru. lights?
Old Aug 7, 2003 | 10:03 AM
.Noah Fecks's Avatar
Default Re: Try checking your fuses... (sleeper4dr)
this same thing happend to my GFs truck. same exsact **** actually. it was a relay. good luck finding it
Old Aug 7, 2003 | 11:52 AM
BdoubleU's Avatar
Default Re: Taillights, guages,instrument light not working (4speed)
There are only a couple of relays in the car so its not to hard. They are under the drivers dash as well. Do you have a manuel? Trouble shooting is much easier with one and there are wiring schematics in the back which could help you find the problem.
Good luck
Brian
Old Aug 7, 2003 | 01:42 PM
4speed's Avatar
its defenitly not the fuses, ive changed all of them, checked them, the whole shmeel, it must be this reley thing, i dont have a manual
cor4ey
Apr 16, 2010 03:53 AM
barnie
Sep 7, 2009 07:45 PM
headrec*
10
Jul 15, 2008 10:35 PM
screamo
Feb 26, 2005 03:34 PM
James
Jan 10, 2003 04:06 AM
