HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan
Old Aug 7, 2003 | 08:13 AM
2000vsm's Avatar
Default HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan
Ok here is my problem from so long ago....
I want to the stainless steel with -AN fittings at the end ON BOTH SIDES... my problem is at the turbo, NOT AT OIL PAN, i'm fine at oil pan for now. here's what i want
HERE IS MY FITTING ON MY TURBO SIDE
See, it's a stupid barb type of fitting.. bullshit
so i was thinking of cutting the metal pipe part off my peice of **** turbo flange thing and then welding this fitting in place of it...
but this is an alunminum fitting,, i have no idea if my oil return is steel or alumnium... what should i do? i don't know if it even fits, that's why i took a pic of the measurement to show you guys... about 1.25" or so
btw: my turbo is a ihi rhb5, not those t25, i dunno if i can even buy the ready made flanges....
Old Aug 7, 2003 | 08:19 AM
Dee's Avatar
Dee
Default Re: HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan (2000vsm)
The turbo in the first pic has a 1/2" npt outlet adapter. You need to get that adapter plus a 1/2" to AN -10 adapter to connect to the -10 (45* or straight) hose end. Using a 45* hose end would take out the low spot that is in the picture above.
Old Aug 7, 2003 | 08:20 AM
2000vsm's Avatar
Default Re: HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan (Dee)
are you certain that that same adapter can fit my TURBO?
Old Aug 7, 2003 | 08:49 AM
Overblown-Teg's Avatar
Why not measure your bolt spacing and call some places that sell them.. I'm sure the guys at turbopiping.com will help you.. if that garret flange won't fit then you can weld the an fitting to it.. Summit sells them. There is nothing wrong with doing it the stock way.
Old Aug 7, 2003 | 09:14 AM
Civic Power's Avatar
New User
Call up http://www.bakerprecision.com/
And get the fitting in steel and then weld it on the nipple fitting that goes onto the turbo and your done
David
Old Aug 7, 2003 | 09:26 AM
project dc2's Avatar
Default Re: HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan (Civic Power)
or just order a threaded flange from RRE its 13$ for a T series oil return flange and order a 1/2 NPT to 10-AN fitting.
Old Aug 7, 2003 | 09:30 AM
2000vsm's Avatar
Default Re: HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">or just order a threaded flange from RRE its 13$ for a T series oil return flange and order a 1/2 NPT to 10-AN fitting. </TD></TR></TABLE>
i have a IHI RHB5
justYncredible
Feb 8, 2012 10:20 AM
dart2.2
Jul 25, 2008 07:01 AM
teamV eg
Jun 28, 2006 04:14 PM
Autoworks
May 31, 2006 08:37 PM
reignofchaos
Jul 31, 2003 07:48 PM
