Hand brake warning Light
Old Aug 6, 2003 | 07:35 PM
Si_LuDer's Avatar
Default Hand brake warning Light
My Handbrake warning lamp keeps appearing while Im driving it appeared to start last night. it would light up when I took off but when I took my foot off the accelerator it would dissappear. now this morning it says on!
Im not silly and I have the handbrake down proporly. when applying the handbrake the light actually gets brighter and when let down the hand brake the light still stays on.
not sure where I should be looking.. it seems to be an electrical fault. also my 4ws also disengaged itslef this morning. not sure if that was coincidence but turning off and re-egaging the motor fix that.
Any Ideas?
Old Aug 6, 2003 | 08:20 PM
Prelude Vtec 23's Avatar
Default Re: Hand brake warning Light (Si_LuDer)
check your brake fluid first
Old Aug 6, 2003 | 09:38 PM
Si_LuDer's Avatar
Default Re: Hand brake warning Light (Prelude Vtec 23)
that would be strange.. I will check it, I had my front Discs replaced the other week with new DOT4 fluid blead through them.. I will check it out when I get home
Old Aug 6, 2003 | 11:07 PM
kidaniel's Avatar
I agree, most likely brake fluid. Just bled my brake fluid
Old Aug 7, 2003 | 05:14 AM
Sephro's Avatar
Default Re: Hand brake warning Light (kidaniel)
Yeah brake fluid all the way. I had the same problem. I was pissed I looked at my brake fluid and it looked to me like it was full. I ripped the center console apart to check the e-brake switch and it was fine. I just figured it couldn't hurt to add a little more fluid and voila! All better.
Mine was doing that whole light getting a little brighter deal too.
Old Aug 7, 2003 | 10:27 PM
Si_LuDer's Avatar
Default Re: Hand brake warning Light (Sephro)
Excuse me for the stupid questions but does it matter if a mix a different brake fluid in. my brakes were done at a brake shop so Im unsure what fluid they used, or should I callem and ask?
Old Aug 8, 2003 | 05:10 AM
Sephro's Avatar
No it should not matter the brand but you should use the same type of brake fluid. If you still have your bill from the shop it might say on it or just call the shop and ask what kind of fluid they use. Just don't use DOT 5
Old Aug 8, 2003 | 06:16 AM
SKDRCR's Avatar
Is there a sensor for the brake fluid level
on the master clyinder somewhere
Old Aug 8, 2003 | 06:27 AM
Sephro's Avatar
Default Re: Hand brake warning Light (SKDRCR)
it's in the reservoir. There are 2 wires that come out of the cap.
Old Aug 8, 2003 | 07:44 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">it's in the reservoir. There are 2 wires that come out of the cap. </TD></TR></TABLE>
i have a 92 lude, i didn't see any wires on there
Old Aug 8, 2003 | 08:23 AM
Sephro's Avatar
I also have a 92 and they are there. It's like they are in the threads of the cap. You can see them on this pic
Old Aug 8, 2003 | 08:29 AM
Si_LuDer's Avatar
considering it is 2:30am AUS time I will check it out in the morning
Will post if this fixed the issue
Old Aug 8, 2003 | 09:53 AM
SKDRCR's Avatar
which resevior is located on the right side by
the junction box w/all the relays
you got two on one side one on the other
Old Aug 8, 2003 | 09:58 AM
Sephro's Avatar
The one that is over by the Fuses is the ABS. The one farthest to the drivers side is the Clutch.
Old Aug 10, 2003 | 04:54 AM
Si_LuDer's Avatar
thanks for the assistants guys, I checked my brake fluide atit was empty tothebottomof the resevoir. topped back up with some DOT4 fluid andno more lights.
Old Aug 10, 2003 | 06:07 AM
prelude1897's Avatar
All you really need to do is look for simple things and that usually fixes problems in your car
sullycrx
Nov 16, 2005 09:48 PM
TRN
May 24, 2004 12:03 PM
Sergei01
Mar 28, 2004 09:26 PM
Proper
Jul 26, 2002 05:57 AM
hybridbmw
Feb 19, 2002 10:38 AM
