need to recalibrate my tps
Old Aug 6, 2003 | 01:54 PM
realblag's Avatar
Default need to recalibrate my tps
I gotta 94 ex. Before I got the car some assbag was nice enough to break the connector off the tps. I removed it and soldered wires to stubs of the contacts and hooked those to the appropriate wires in the connector. Unfortunately, I was not smart enough to mark the tps's position on the throttle body. I know you set them with a ohm meter but what are the values, which wires do you measure, and how do you do it?
Old Aug 6, 2003 | 03:03 PM
drunknbass's Avatar
use a multimeter or voltomiter or whatever.. but its .5 and idle and 4.5 at wot
Old Aug 6, 2003 | 04:21 PM
realblag's Avatar
Default Re: (drunknbass)
whoaaaa! Is that volts or ohms?
Old Aug 6, 2003 | 04:25 PM
Bnjmn's Avatar
Default Re: (realblag)
volts.
Old Aug 6, 2003 | 04:30 PM
realblag's Avatar
Default Re: (Bnjmn)
So, ignition on, measure the voltage at idle position and then move the tps till it reads .5 volts. Will this make it read correctly at wot?
Old Aug 6, 2003 | 04:46 PM
drunknbass's Avatar
should if your tps isnt fucked. just open the throttle all the way and see what it reads..
Old Aug 6, 2003 | 05:21 PM
realblag's Avatar
Default Re: need to recalibrate my tps (realblag)
Well I went and did what you said and low-and-behold it worked like a charm. Thanks for the help drunknbass and Bnjmn!
dc5RickK20
Dec 3, 2007 07:19 AM
iphatcrxi
Oct 5, 2006 08:49 AM
smkngsr
May 9, 2005 07:06 AM
TheHatchHog
May 15, 2003 06:16 AM
Mike813
Mar 19, 2003 07:04 AM
