Question About the B&M Edge Short Shifter vs B&M Pro Edge SS.
Old Aug 6, 2003 | 12:23 PM
Modifiyem's Avatar
Default Question About the B&M Edge Short Shifter vs B&M Pro Edge SS.
what is the difference between the edge short shifter and the pro edge short shifter?
Edge ss is cheaper than the other one. Could the b&m edge ss be installed from inside of the car where the stock shifter is or It has to be installed from under neath the car? The pro edge ss has some parts at the bottom of it but the edge ss doesn't have it. What are they?
Thank you.
Old Aug 6, 2003 | 04:43 PM
EG_93Civic's Avatar
Default Re: Question About the B&M Edge Short Shifter vs B&M Pro Edge SS. (Modifiyem)
yea, i want to know too
Old Aug 8, 2003 | 05:04 AM
Modifiyem's Avatar
?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modifiyem &raquo;</TD></TR><TR><TD CLASS="quote">what is the difference between the edge short shifter and the pro edge short shifter?
Thank you.
Old Aug 8, 2003 | 06:49 AM
DCStreetHtch's Avatar
all short shifters require you to get under the car for some wrenching!
-Bryan-
Old Aug 8, 2003 | 09:10 AM
Mt3c's Avatar
25 Year Member
the edge is just the shifter rod, along with some o-rings. Replaces just the factory shifter.
pro edge comes with above and a new ball housing thing. i don't know what its exactly called, but here's the pic.
if pics don't work, go here and check the price difference also.
as stated above, all shifters will require you to get underneath the car to replace
I use to have the edge in my civic, but i didn't use it in my integra. it doesn't have the double bends the stock shift has, and it will push the shifter away from u. but the shifter is a very nice piece and well built. never heard of anybody breaking one either, unlike the aluminum pieces.
Old Aug 8, 2003 | 10:14 AM
xteg95's Avatar
Default Re: Question About the B&M Edge Short Shifter vs B&M Pro Edge SS. (EGStreetHtch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGStreetHtch &raquo;</TD></TR><TR><TD CLASS="quote">all short shifters require you to get under the car for some wrenching!
-Bryan-</TD></TR></TABLE>
i got the "non-pro" one, dont see why you would need that extra part.
Old Aug 8, 2003 | 01:47 PM
Modifiyem's Avatar
Default Re: Question About the B&M Edge Short Shifter vs B&M Pro Edge SS. (Mt3c)
If that's the case, why is the pro edge is more expensive?
The edge shifter reduces the shift as much as the other ones, right?
What's the purpose of those o-rings on pro?
You said, it replaces the factory shifter, does that mean, it doesn't reduce the shift?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c &raquo;</TD></TR><TR><TD CLASS="quote">the edge is just the shifter rod, along with some o-rings. Replaces just the factory shifter.
I use to have the edge in my civic, but i didn't use it in my integra. it doesn't have the double bends the stock shift has, and it will push the shifter away from u. but the shifter is a very nice piece and well built. never heard of anybody breaking one either, unlike the aluminum pieces.</TD></TR></TABLE>
Old Aug 11, 2003 | 03:21 PM
Mt3c's Avatar
25 Year Member
both reduce the shifting throw. the orings are for the part that connects to the shift linkage.
sorry, may have gotten the name confused. the more expensive one is the one with the housing thing.
if u have any more questions, may i suggest emailing b&m at http://www.bmracing.com/ . hth
Old Aug 11, 2003 | 06:50 PM
NightmareApex's Avatar
short shifters are stupid, all they do is allow you to miss shitft and hurt your car.
Old Aug 11, 2003 | 07:14 PM
dom93hatch's Avatar
Default Re: (NightmareApex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightmareApex &raquo;</TD></TR><TR><TD CLASS="quote">short shifters are stupid, all they do is allow you to miss shitft and hurt your car.</TD></TR></TABLE>
Mr. observant
Maybe you should learn to shift properly.
Old Aug 12, 2003 | 05:27 AM
midnightdarknes5's Avatar
Default Re: (dom93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom93hatch &raquo;</TD></TR><TR><TD CLASS="quote">
Mr. observant
Maybe you should learn to shift properly.</TD></TR></TABLE>
lolz
Old Aug 12, 2003 | 08:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
apparently you have never driven a car with a light-weight flywheel. On my car w/ the 7.5lb. Cluthmasters flywhee, a short throw shifter greatly helps when trying to shift and not let the revs drop too much.
As for the B&M Pro edge, I think that housing piece allows some sort of height/throw adjustment, but I'm not sure.
Old Aug 12, 2003 | 08:44 AM
VTechie's Avatar
Default Re: (PatrickGSR94)
You're right-
The housing on the pro-edge contains a bearing located by two snap rings. By changing which grooves the snap-rings are in, you can change the throw to one of three settings. The longest throw (I think) is like the B&M Edge. The shortest throw is wicked short. I have mine in the middle.
One note- when the Pro-Edge has been in for a while (3000 miles or so) it starts to rattle like a **** at certain rpm. It is not related to anything touching the exhaust system or anything like that. I so far have not found any cure for it.
Old Aug 12, 2003 | 11:30 AM
xteg95's Avatar
Default Re: (VTechie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTechie &raquo;</TD></TR><TR><TD CLASS="quote">
i think thats a common problem w/all b&m short shifers...i know mine has the same problem.
Old Aug 14, 2003 | 07:55 PM
REDBARON's Avatar
Like VTechie said, the Pro shifter has the throw adjustment, and that's why it's more expensive. My brother has the edge, and I have the Pro, and he's always commenting on how shorter my throw is compared to his. I have it on the lowest setting though. But I have had mine on for about 10K miles, and it doesn't rattle at all. Not sure why your does.
Old Aug 15, 2003 | 07:38 PM
u2 are morons, for one I have a lightened flywheel, and u dont have a 7.5lb flywheel, thats not streetable, anyhow short shifters are RICE, ur oem shifter is the best. Also short shifters dont throw ur syncros in ur tranny off, and mess up ur trans mission. Also when racing under extreme conditions say for instance; slowing down from 120mph in a straight into a 60 mph turn and u need to down shift in the turn its easy to miss shift with a short shifter.
Old Aug 15, 2003 | 08:07 PM
djay86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightmareApex &raquo;</TD></TR><TR><TD CLASS="quote">u2 are morons, for one I have a lightened flywheel, and u dont have a 7.5lb flywheel, thats not streetable, anyhow short shifters are RICE, ur oem shifter is the best. Also short shifters dont throw ur syncros in ur tranny off, and mess up ur trans mission. Also when racing under extreme conditions say for instance; slowing down from 120mph in a straight into a 60 mph turn and u need to down shift in the turn its easy to miss shift with a short shifter. </TD></TR></TABLE>
Ok.. i really dont think he would lie or make up something about his flywheel... how are short shifters rice? So some of the finer producer of short shifters is rice? Skunk2? DC Sports? C's ?
Just because you dont like short shifters, doesnt mean other people dont either. If you want to have a precise and short shift, get a short shifter... if you like stock, stay with stock...
Old Aug 16, 2003 | 10:34 AM
rodimus's Avatar
Default Re: (djay86)
i've heard great things about the C's and the JDM ITR shifter.
Old Aug 16, 2003 | 02:17 PM
Tweakmeister's Avatar
Default Re: (EVOL)
I run the Neuspeed.
-0 misshifts
-you get used to the throw really quickly
-only I don't like is it sits a tiny bit lower
phatboy4242
Aug 21, 2007 08:08 PM
...civic...
Mar 15, 2006 02:37 PM
^LORTA^RACING
25
Mar 12, 2005 08:31 AM
G2DAteg
Dec 1, 2004 11:11 PM
P73 DA9
Jul 19, 2001 05:19 AM
