Where to find RSX type R heads?
My title is incorrect!
Where can I buy Integra type R DC5 heads from?
Are TSX heads the same?
I looking for the 3-lobe cam heads with cams, does anyone know where to get this at?
Modified by SI_DRIVR at 9:38 PM 8/6/2003
I've got a 2.4L block.
I was told the the Integra Type R K series engine head is the same as the TSX. The Type R head is for 2.0L block, but still fits like the B-series head fits a B20 block instead of the 1.6 & 1.8L block.
I can't find any of the heads yet for sale. The type R head has a 3-lobe cam I'm hoping the the TSX head is the same way. Let me know if you find anyone that sells the head
Is there just a difference in the cams then? I was told one head is for a 2-lobe cam and one head is for a 3-lobe head.
Is the K20A2 head on the Type R and TSX?
K20A2 is the TypeS motor. K20A3 is the Si motor. The K20A3 head is different than the K20A2 head. It's VTEC mechanism is different. It does onlyhave two lobes.
Here's the part number for both the K20A and the K20A2 heads:
12100-prb-a00
Check out this thread for more info:
http://forums.clubrsx.com/show...+head
12100-prb-a00
Can you guys give me the TSX head part number instead
I've already got a 2.4L block so I just need the better head flow characteristics and the TSX head should be perfect.
Okay20
35
Jul 19, 2002 02:16 PM
