What else should I get for my N/A B16??
Old Aug 6, 2003 | 10:14 AM
B16CRXSi's Avatar
Default What else should I get for my N/A B16??
I have a 90 CRX Si with a B16a.I am not sure what I am going to run with the parts I have now. I am thinking mid 13's. I just figured I would see if there was anything else I should get before I finish putting the motor together and in the car.
So far I have:
ACT Organic Street Disc
ACT Heavy Duty Pressure Plate
AEM CAI system
Apexi Rev/Speed Meter with G-Sensor
Apexi V-AFC
ARP Head Studs
B&M Fuel Pressure Regulator and gauge
Bottom-end Gasket Kit
C&R Racing Rad
Fidanza Flywheel
Gude Head Package
LSD tranny
MSD SCI Ignition Kit
Mugen Fan Switch "Thermoswitch"
Mugen Low-Temp B-Series Thermostat
Place Racing Front Crossmember (EF)
Place Racing Throttle Cable Bracket (EF)
STR Racing Adj. Cam Gears
STR Racing Fuel Rail
STR Block Gard
STR Aluminum Cam Seal
Top-end Gasket Kit
Unorthodox Racing Ultra A Alternator pully
Unorthodox Racing Ultra R Underdrive pully
The Gude Head package consist of:port and polish head, 3 angle valve job, over bore throttle body, port and polished intake manifold, cams, and ECU.
I have other parts. these are just the ones for the motor.
Sooo what do you think I will run and what else should I get??
Old Aug 6, 2003 | 10:17 AM
WAFFLES's Avatar
Default Re: What else should I get for my N/A B16?? (B16CRXSi)
Ditch that Gude ****. It's junk.
Old Aug 6, 2003 | 10:21 AM
B16CRXSi's Avatar
Default Re: What else should I get for my N/A B16?? (WAFFLES)
I can't ditch it. Thats 50hp at the wheels and I spent $1400 on it. Thats to much money to not use it!
advanracing62's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">Ditch that Gude ****. It's junk.</TD></TR></TABLE>
ditto- I'm betting you won't be as fast as that. I realize you have a CRX, but it took JUN III and some gutting to get my B16 powered hatch into the 13's, major gutting and we ran 12.9
Old Aug 6, 2003 | 10:30 AM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXSi &raquo;</TD></TR><TR><TD CLASS="quote">I can't ditch it. Thats 50hp at the wheels and I spent $1400 on it. Thats to much money to not use it!</TD></TR></TABLE>
Sucks to be you man.
Old Aug 6, 2003 | 10:31 AM
stevel's Avatar
no way it'll be 50hp at the wheels.
s
Old Aug 6, 2003 | 10:43 AM
Default Re: What else should I get for my N/A B16?? (stevel)
who told you that!?!?! JUN III cams with some decent tuning netted 33 whp... that's a ton! there's no way Gude crap will give you 50... If it does I'll sell you my car for .25
Old Aug 6, 2003 | 11:14 AM
allmtr's Avatar
Default Re: What else should I get for my N/A B16?? (advanracing62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote"> there's no way Gude crap will give you 50... If it does I'll sell you my car for .25</TD></TR></TABLE> i second that
Old Aug 6, 2003 | 11:16 AM
WAFFLES's Avatar
Default Re: What else should I get for my N/A B16?? (allmtr y0!)
Gude=no gude(play on words)
Old Aug 6, 2003 | 11:33 AM
B16CRXSi's Avatar
sweet. .25 thats a steel. do you have any pics of your car? Gude guaranties 50HP at the wheels.
Old Aug 6, 2003 | 11:53 AM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXSi &raquo;</TD></TR><TR><TD CLASS="quote">sweet. .25 thats a steel. do you have any pics of your car? Gude guaranties 50HP at the wheels.</TD></TR></TABLE>
bwaaaaaaahahaha...Please show me their GARAUNTEE. I will garauntee you their stuff is junk.
1) Never seen any of their cams make power.
2) Never seen any of their ECUs that are worth a crap.
I'm not hating on you man, for real good luck...Just letting you know that I have NEVER met anyone who has used Gude Products that have actually had good results...EVER. Besides, 50whp is a ******* lot on a N/A B16.
Old Aug 6, 2003 | 01:46 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXSi &raquo;</TD></TR><TR><TD CLASS="quote">I have a 90 CRX Si with a B16a.I am not sure what I am going to run with the parts I have now. I am thinking mid 13's. I just figured I would see if there was anything else I should get before I finish putting the motor together and in the car.
So far I have:
AEM CAI system
Apexi V-AFC
ARP Head Studs
C&R Racing Rad
Fidanza Flywheel
Gude Head Package
LSD tranny
STR Block Gard
Top-end Gasket Kit
We are looking to do a 200whp B16 street motor project built by omniman. PM if you are interested.
Old Aug 6, 2003 | 04:52 PM
[tk4L] Doke's Avatar
Default Re: What else should I get for my N/A B16?? (Rocket)
i suggest get rid of the 1.6l they are worthless.
Old Aug 6, 2003 | 07:41 PM
stevel's Avatar
Default Re: What else should I get for my N/A B16?? (futreBoosteR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by futreBoosteR &raquo;</TD></TR><TR><TD CLASS="quote">i suggest get rid of the 1.6l they are worthless. </TD></TR></TABLE>
damn man this is a tech forum. if you've got something stupid like that to say don't even bother.
your comment does nothing to help out with any sort of useful knowledge that people come here to get.
s
Old Aug 6, 2003 | 07:43 PM
allmtr's Avatar
ROFLMAO! but seriously...
Old Aug 6, 2003 | 11:05 PM
Unsung's Avatar
You should be able to acheive mid 13's if you're a good driver and the setup is tuned.
Old Aug 7, 2003 | 04:40 AM
B16CRXSi's Avatar
Default Re: What else should I get for my N/A B16?? (Unsung EM1)
Well i thank most of you for staying on track with the forum. But my other question is what else should i get for my motor and No i'm not getting a new head. I am keeping my gude package. I just hope it works out. So any other suggestions about what else to do with my motor??
Old Aug 7, 2003 | 05:01 AM
reese's Avatar
get a b18 block with high compression pistons
Old Aug 7, 2003 | 06:46 AM
f@sth@tch89's Avatar
without scrolling down to see what others have mentioned. i would say go with some 12:1 compression pistons and some aftermarket rods. You could also get away with stock CTR pistons oversized .25. Im going to assume that this will be a track only car. Also lexan the windows. Fiberglass front end or if its street the CF hood and/or finders.
Old Aug 7, 2003 | 07:39 AM
B16CRXSi's Avatar
Default Re: What else should I get for my N/A B16?? (fasthatch89)
Yeah it's a street/strip car. No lexon windows. It is stripped from the front seats back. I am going to get a carbon fiber hood but that will be awial before i have enough money saved up for that. I want to get a J's Racing double vented hood. It will fit since I have an SiR front end conversion. I am going to at least put some 11:1 pistons and some eagle rods with ARP rod bolts in the block. Just not sure how crazy I want to go.
Old Aug 7, 2003 | 09:43 AM
Charlie Moua's Avatar
I agree with what everyone has said so far about the GUDE thing!
I know when you said package you mean (p/p head work, cams, valvetrain upgrade ect and injectors.
Gude was sorta hot like back in 1999.
They make more power then stock, but not enough to go around claiming what they do on their websites. Gude product have not been proven my anyone worth or on the street,.. its just mainly all hersay and rumors. And everyone will agree with me when I say GUDE's customer service sucks PEROID.
I would honestly try to sell that head package for say..700-800 and get a portflow head with Jun3, TodaC's or the newer EF-1 killer cams. If you think you gain 50 more WHP then you are fooled..sorry but thats the truth. Portflow head with nice cams and you'll definaly feel the difference.
B16 are awesome motors.. don't listen to that dumb-*** and that comment. they are proven motors from day one and all it needs is a little more investment compared to the 1.8 motors.
If I had a B16 I would BORE it out to 85mm and get some at least 11.1cr pistons! you'll feel the differece throught the entire powerband, and it will seriously feel like a differnt motor!
with high compression motor also invest in a good complete cooling system from thermo, head gasket, to radiator ect. they run hotter which is normal. having a B16 make 185whp should be easy(if you have the funds)! making a 210whp B16 is a reall challenge.
my tech guy has a b16 that runs 13's in a hevy *** delsol with 2.2 60ft times
he makes about 210whp & 139tqi think. But he has a jun stroker kit and jun race head package. with CHEAP *** ebay intake and dc 4-1 headers. Now he's thinking about boring it out to 85mm to make it a 2.0 B16a3. Just thought I'd share.
B16 all motor.... cost a lot of money....!
Old Aug 8, 2003 | 04:44 AM
B16CRXSi's Avatar
Default Re: What else should I get for my N/A B16?? (Charlie Moua)
Thanks to everyone for the help. Any more info would be great.
Jdm1996
Jan 3, 2015 06:30 AM
B16CRXSi
Apr 11, 2005 04:18 PM
2point6
Jul 26, 2004 09:17 AM
2point6
Nov 28, 2002 08:05 PM
2point6
Jul 28, 2002 10:41 AM
