Only 198 whp is ECU the problem?
Old Aug 6, 2003 | 08:50 AM
sqwerz
Guest
Posts: n/a
Default Only 198 whp is ECU the problem?
00 ITR 17K B18C5
stock bottom end
Minor headwork
Mugen headgasket
270cc RC injectors
Spoon 70mm throttle body
AEM CAI
JUN Stage 3 cams, valve springs, retainers and cam gears
Exedy flywheel and street clutch--(had JUN flywheel and ACT clutch before)JUN header and full exhaust w/gutted catJUN ECU
Homemade catch-can
removed AC and power steering
Car makes 198.6 whp and 133 ft lbs torque.
best time at e-town with car fully gutted and slicks with skinnys was 12.8 at 106 mphTried hondata and car didnt make anymore power.
On the dyno graph car doesn't make power over the 8200 rpm level.
what do you think?
Old Aug 6, 2003 | 08:54 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Only 198 whp is ECU the problem? (sqwerz)
could be header/exh, or just poor tuning.
Btw, those are actually pretty decent numbers considering you haven`t altered the compression much.
Old Aug 6, 2003 | 09:21 AM
Civichatch2k's Avatar
Really good numbers, for what you have! I would just spend some time tunning a little more! Good luck!
Old Aug 6, 2003 | 09:27 AM
IN VTEC's Avatar
Pretty similar to this?
He has the JUN pistons, so I'd say you're doing pretty good.
Old Aug 6, 2003 | 12:42 PM
letholone's Avatar
Default Re: Only 198 whp is ECU the problem? (IN VTEC)
could be since your headwork is only " minor" that its not done up right to make power in higher rpms.
just cause you hit your peak power at 8200. its not like you took a drastic dip after that, its not the smoothest graph, but its not bad.
your header could be changed out as well.
i think those are great numbers.
Old Aug 6, 2003 | 12:51 PM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sqwerz &raquo;</TD></TR><TR><TD CLASS="quote">Car makes 198.6 whp and 133 ft lbs torque.
best time at e-town with car fully gutted and slicks with skinnys was 12.8 at 106 mph</TD></TR></TABLE>
I think you have to be making well over 198.6 whp to be pulling those times and trap speeds....
Old Aug 6, 2003 | 01:15 PM
Dr. EKology's Avatar
I think its your tuning/tuner. With that set-up you should be able to break 200. See if you can stretch the powerband a little, with those juns 8,200 is pretty low for a redline. Maybe take it to a different shop to see what they can pull out of it.
Old Aug 6, 2003 | 01:36 PM
hYpE-R-29's Avatar
spend more time on the dyno with TUNING
Old Aug 6, 2003 | 03:28 PM
skunked's Avatar
Default Re: Only 198 whp is ECU the problem? (ALLMOTOR18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR18 &raquo;</TD></TR><TR><TD CLASS="quote">
I think you have to be making well over 198.6 whp to be pulling those times and trap speeds.... </TD></TR></TABLE>
That's what I was thinking. Good times
Old Aug 6, 2003 | 04:51 PM
GOLDBERG's Avatar
why?someone here with 197 just did a 12.9 spinnin 24 inch slicks..2.1 60 foot
Old Aug 6, 2003 | 05:17 PM
rodimus's Avatar
Default Re: Only 198 whp is ECU the problem? (GOLDBERG)
ctr pistons.
Old Aug 6, 2003 | 07:54 PM
Mr Hammond's Avatar
a/k/a Jomo
Not at all.
So wait what exactly do you mean you "tried Hondata and it didn't work"? I find that really hard to believe that Hondata made nothign over you "JUN ECU".
Old Aug 6, 2003 | 08:31 PM
kwik93si's Avatar
you'll need higher compression to really benefit from those big cams.
Old Aug 6, 2003 | 08:37 PM
sqwerz
Guest
Posts: n/a
Default Re: Only 198 whp is ECU the problem? (Mr Milano)
spent at least 5-6 hrs total on three different days and that was all the hp it made.
the hondata made almost the same power. maybe 1-2 hp less than the JUN.
thanks for all the comments and suggestions
Old Aug 6, 2003 | 11:09 PM
98itR484's Avatar
198whp w/ a stock ITR bottom end on JUN's is actually what you should be at, give or take a few whp, you wont make 220 w/ a stock bottom end.
edit: sorry...didnt see the JUN header part
I would ditch the JUN header and JUN ECU,
Get a SMS/Toda/Hytech header and either buy hondata or wire up a VAFC and tune the bitch the JUN ECU has to be the most over priced thing on this planet, next to womens purses
Old Aug 7, 2003 | 01:52 AM
TRAN's Avatar
NOT true
Old Aug 7, 2003 | 10:32 AM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">
So wait what exactly do you mean you "tried Hondata and it didn't work"? I find that really hard to believe that Hondata made nothign over you "JUN ECU".</TD></TR></TABLE>
Hondata didnt work for me either. I had an XS Engineering chipped P72 and replaced it with and S100 hondata system. When I got tuned with hondata, there were no gains more than 2 whp.
Old Aug 7, 2003 | 07:41 PM
F1Spec's Avatar
hondata will not work if you dont have a good tuner. running on a basemap will not gain you power, in most cases, you will lose power. i gain at least 10whp+ using hondata and 1 hour of tuning. my tuner is very familiar with hondata system and knows how to tweak right away after 1st run baseline pull.
as for the e.t., i think he did just fine.
i went 12.9@105 with 189whp/139wtq. this is with 15 inch slicks (23.5x7.5x15).
Old Aug 7, 2003 | 11:19 PM
ALLMOTOR18's Avatar
Default Re: Only 198 whp is ECU the problem? (s2geezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2geezy &raquo;</TD></TR><TR><TD CLASS="quote">i gain at least 10whp+ using hondata and 1 hour of tuning. my tuner is very familiar with hondata system and knows how to tweak right away after 1st run baseline pull.
who is your tuner? I want to try another hondata tuner to see if I can make more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2geezy &raquo;</TD></TR><TR><TD CLASS="quote">as for the e.t., i think he did just fine.
i went 12.9@105 with 189whp/139wtq. this is with 15 inch slicks (23.5x7.5x15).</TD></TR></TABLE>
What chassis did you pull your 12.9 in?
189 whp is enough to do it in a EG, but to do it in an integra chassis it will take more whp..
Old Aug 8, 2003 | 01:18 AM
GapxGuy's Avatar
Sushi Buffet Champion
That's it?? That's pretty good numbers!
Old Aug 8, 2003 | 09:41 AM
rodimus's Avatar
Default Re: Only 198 whp is ECU the problem? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons.</TD></TR></TABLE>
oh yah and headers/tuning.
what kind of exhaust are you running
Old Aug 8, 2003 | 11:54 AM
skunked's Avatar
189 whp is enough to do it in a EG, but to do it in an integra chassis it will take more whp.. </TD></TR></TABLE>
s2geezy ran that time in a ITR chassis.
I have ran 12.9's also in a DC chassis with 194whp & 140 wtq. You don't need 200+ whp to run a 12 sec et in a DC chassis.
Old Aug 8, 2003 | 03:27 PM
BERT-O's Avatar
Default Re: Only 198 whp is ECU the problem? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
I have ran 12.9's also in a DC chassis with 194whp & 140 wtq. You don't need 200+ whp to run a 12 sec et in a DC chassis.</TD></TR></TABLE>
So true,
Traction, good driving skill, traction, drivers' skills and more traction = fast et's
BTW, 198whp with Jun3's with that compression is not bad.
Old Aug 8, 2003 | 04:26 PM
ALLMOTOR18's Avatar
Old Aug 8, 2003 | 06:18 PM
sqwerz
Guest
Posts: n/a
i had DRT tune the car is Queenz. he was there for hours trying to tune the car and it didnt make no more power
and he is a Pretty good tuner. Also tried a half-pipe in place of the jun muffler.
