Duplicolor wheel paint
Old Aug 8, 2001 | 08:41 PM
Tanner's Avatar
New User
Default Duplicolor wheel paint
Anyone seen the add in the new SCC about there rim paint and I checked there web site and they say it holds up to weather (which I dont have to worry much about living in the desert) and is durable paint. So what do you guys think does it sound any better than just regular spray paint I want Gunmetal rims BAD but cant afford a powder coat..
Old Aug 9, 2001 | 11:11 AM
RineRacing's Avatar
Default Re: Duplicolor wheel paint (GS-Racer01)
I painted my racing rims with plain duplicolor enamel. The finish has held up for a month now with some very very minor chips. The only problem is the paint wore off where the lig nuts make contact with the rim but that remains hidden by the nut. It depends on what the rims are for. Racing, spray paint them. Show, powder coat them. I didn't try the dupli-color "rim paint" because it doesn't come in flat black.
One last thought, if you scrape the rim on a curb or something like that you just blew one expensive powder coat job unless you used spray paint in which you can just clean it up and reapply more paint.
[Modified by Geratol, 12:14 PM 8/9/2001]
Old Aug 9, 2001 | 02:43 PM
Tanner's Avatar
New User
Default Re: Duplicolor wheel paint (Geratol)
Cool man thanks I think I am gonna give it a try, the only thing that is holding me back is ruining my stock rims which I really like that is the main reason I ask. The car is not a show car it is all about the go well mostly go. Cant say all or I wouldnt even want to be painting the rims, eh. Anyways thanks for the info, I think I will call them duplicolor and see what it will cost to paint my rims with there rim paint.
Old Aug 10, 2001 | 11:30 AM
RineRacing's Avatar
Sand Paper (600 grit)
Grease, Tar, Wax Remover
Primer (2-3 Cans)
Enamel (3-4 Cans)
Total Cost - ~$40 (somewhere around there)
Remember take your time, and preparation is the key. Sand well, clean well, spray well.
Old Aug 10, 2001 | 11:49 AM
slowerthanu's Avatar
New User
I went to my local auto body supply store and picked out a dope GM metallic gray that kicks ****. check it ckeck it out y'all
Old Aug 10, 2001 | 11:52 AM
New User
Default Re: Duplicolor wheel paint (slowerthanu)
And for your information, I used 1.5 cans NO primer alot of sanding and tar a wax and grease remover I used laquer thinner on the tires so the tape would stick extra good and took my time. Those wheel's on my car have been painted 3 times and came from Racing Hart powdercoated white
Old Aug 10, 2001 | 01:11 PM
Tanner's Avatar
New User
You have any closer pics?? They look dope, but they are like right in the shade and kinda hard to see..
Old Aug 11, 2001 | 01:40 AM
Erik_Pb_Foot's Avatar
New User
I want that Redline oil banner.
POwdercoat all the way.
japspecjohn
Paint and Body
19
Jun 9, 2007 02:28 AM
greasmanky
Dec 4, 2005 08:39 AM
sjteg
Sep 3, 2003 06:58 PM
zer0zer0 TypeR
May 29, 2002 07:28 AM
