RSX Spoon lower rear tie bar = EP3?
Anyone know if the Spoon rear lower tie bar from the RSX will fit on the EP3?
Spoon has the same first part numbers, but the middle are different (one says EP# on says RSX) 74351-EP3-000
hey Todd00
why do u even wanna buy spoon rear lower tie bar..??cause u can even get reactive one too, trust me i check on the stiffnest on that bar..u can't bend with the new one, coz is short. is not worth it to buy a more expensive one for the rear lower tie bar...i understand if u buy the front and rear upper spoon is different, honestly is not worth it save ur money on other things....yes the rsx, civic are the same...
I have the Sppon rear lower tie bar on my S, but I do not know if it will fit on the Si. I can measure from bolt to bolt on the rear lower tie bar for you and maybe that can help.I'll measure in a while, I'm at work at the moment and my car is outside.
Ok I just took my *** out to my car with a ruler in some hot *** weather to get this bro.
From bolt to bolt on the rear lower tie bar, it is about 15 1/2 inch's. So if you measure from bolt to bolt and it is 15 1/2 inchs then it will fit.
Hope that helped bro. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1nal zeros »</TD></TR><TR><TD CLASS="quote">Ok I just took my *** out to my car with a ruler in some hot *** weather to get this bro.
Hope that helped bro. Good luck.</TD></TR></TABLE>
You're the man!
I'll measure mine when I get home tonight. Since the swaybars all interchange, I don't see why the bar will not--but you never know.
You're the man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
You're the man!
I'll measure mine when I get home tonight. Since the swaybars all interchange, I don't see why the bar will not--but you never know.</TD></TR></TABLE>
I do not see why it would not fit your Si. Everything that a RSX has can fit on a Si, Damn things are almost the same anyways. I hope the bar fits bro, you will notice a bit of difference after you install it. Good Luck.
You're the man!
