RC engineering Saturated 310 C.C. injectors!
Old Aug 8, 2001 | 07:46 PM
slowerthanu's Avatar
New User
Default RC engineering Saturated 310 C.C. injectors!
As some of you know I have purchased the JUN lll head package. I plan on purchasing the JUN piston's and rod's with the bonus I will recieve at the end of my tenure with the Olympics. Now for my question to you guy's (and girl's). If I use the JUN ECU along with the rest of there parts I should end up with a 12:3-1 compression ratio, now with this compression ratio along with the type-3 cams, do you guy's think I should purchase 270cc 310cc or stick with my stock injectors (240cc?).
Any help would be greatly appreciated.
Old Aug 8, 2001 | 09:59 PM
98TypeR's Avatar
Default Re: RC engineering Saturated 310 C.C. injectors! (slowerthanu)
i have 12.5 compression and i have the same dilemna. If you want over 220 hp then get 310's but if you aren't searching for more than that. YOu might have to run low fuel pressure and not get correct spray pattern.
Old Aug 8, 2001 | 11:02 PM
NAB20C5's Avatar
Default Re: RC engineering Saturated 310 C.C. injectors! (98TypeR)
I use 310's w/ my set up at 12.5:1 and works great, um not sure what the Jun ECU will do, but w/ my FC they are pretty much set at stock @ 100% @ idle, and 55 psi w/ vacuum on fuel pressure, best of luck
Old Aug 9, 2001 | 07:31 AM
Austin's Avatar
I have 310's installed and without an increased Fuel Pressure the PowerFC told me that I was hitting 98.6% duty cycle while running around buttonwillow, but then again I don't have it fully tuned just yet, so who knows what I'll be running at when I'm done.
Austin
Old Aug 9, 2001 | 07:42 AM
ZygSpeed's Avatar
Default Re: RC engineering Saturated 310 C.C. injectors! (itrAustin)
Did you guys get the Power FC, straight from Apex-i or some other dealer?
IM me if you like, looking to use one with FI and 440 injectors (I'd get it all from the same place if I could).
thanks, ed
[Modified by zygspeed, 11:44 AM 8/9/2001]
Old Aug 9, 2001 | 11:39 AM
New User
Default Re: RC engineering Saturated 310 C.C. injectors! (zygspeed)
Thanks for the help
Old Aug 9, 2001 | 11:48 AM
NAB20C5's Avatar
thanks, ed
No way, Mr. Zygspeed is goin F/I? oooo haha well yeah they work great w/ the FC and 440's and a 2bar map or the 3 bar from apexi on 14+ psi....I got mine through a friend and you can either go through Dan/God or XS engineering in Kalifornia
hip_hop_s0ulchild
Oct 26, 2005 05:47 AM
GapxGuy
Apr 25, 2004 01:21 PM
Project92Hatch
Sep 30, 2003 10:24 AM
SIReg9
Feb 17, 2003 07:55 PM
