made a velocity stack intake today
Old Aug 5, 2003 | 11:08 PM
Lamchop0000's Avatar
Default made a velocity stack intake today
i made a velocity stack intake. i got the velocity stack at http://www.summitracing.com its made by RS akimoto. the pipe there is a cut section of "hooker" exhaust piping. pipe size is 2 1/2" pics arnt too great, because there from a webcam. painted with BBQ grill paint from homedepot. im waiting for my pipe coupler to come in the mail so i can give this intake a try. so, enjoy?
Old Aug 5, 2003 | 11:11 PM
mmuller's Avatar
Mad Scientist
Default Re: made a velocity stack intake today (lamchop0000)
looks very good
Old Aug 5, 2003 | 11:14 PM
AllMotorHB's Avatar
Dude, Home Depot BBQ paint is AWESOME I Love that crap. O yea intake coming along nicely 2. Keep us updated homie Lam.
Old Aug 6, 2003 | 01:06 AM
-Racer X-
Guest
Posts: n/a
Default Re: made a velocity stack intake today (AllMotorHB)
i wanna see dynos.
Old Aug 6, 2003 | 01:11 AM
AllMotorHB's Avatar
Default Re: made a velocity stack intake today (-Racer X-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Racer X- &raquo;</TD></TR><TR><TD CLASS="quote">i wanna see dynos.</TD></TR></TABLE>
pitch in and pay for a dyno run This man is broke as a joke and sharp as a beach ball haha j/k
Old Aug 6, 2003 | 03:44 AM
J2turbo21's Avatar
Is that BBQ paint like a wrinkle paint?Nice job by the way.
Old Aug 6, 2003 | 10:16 AM
the BBQ paint is flat like 2000grit sand paper. im not sure how wrinkle paint feels like.
oh yeh, ill let you know how the butt dyno goes, haha.
Old Aug 6, 2003 | 11:08 AM
Tweakmeister's Avatar
Default Re: (lamchop0000)
direct link: http://store.summitracing.com/...stack
Old Aug 6, 2003 | 12:28 PM
ophdehEEzY
Guest
Posts: n/a
where does the filter go?
Old Aug 6, 2003 | 12:40 PM
-Racer X-
Guest
Posts: n/a
Default Re: made a velocity stack intake today (ophdeheezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ophdeheezy &raquo;</TD></TR><TR><TD CLASS="quote">where does the filter go?</TD></TR></TABLE>
haha...
or wait...are you serious?
Old Aug 6, 2003 | 12:43 PM
WAFFLES's Avatar
What does a "velocity stack" do anyways?
Old Aug 6, 2003 | 01:11 PM
NA gs-R 05 C
Guest
Posts: n/a
looks good.
Old Aug 6, 2003 | 04:17 PM
dfoxengr's Avatar
Default Re: made a velocity stack intake today (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">What does a "velocity stack" do anyways? </TD></TR></TABLE>
stacks up velocity duh.
basically rams air into the intake.
Old Aug 6, 2003 | 04:22 PM
preluda92's Avatar
Default Re: made a velocity stack intake today (hybridvteceg)
Just need to figure out how to filter that.... I'm too paranoid to run without a filter. Anyone think it'd be worth it to replace your stock resonator with a cold-air velocity stack leading into the stock airbox?
Old Aug 6, 2003 | 04:23 PM
dfoxengr's Avatar
Default Re: made a velocity stack intake today (preluda92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 &raquo;</TD></TR><TR><TD CLASS="quote">Just need to figure out how to filter that.... I'm too paranoid to run without a filter. Anyone think it'd be worth it to replace your stock resonator with a cold-air velocity stack leading into the stock airbox?</TD></TR></TABLE>
its for track use only
Old Aug 6, 2003 | 08:43 PM
well i was thinking of a screen filter.
cap it around the end of the pipe, insert the pipe coupler, then stick on the velocity stack end. just to block out chucks of junk. or cut up a K&N factory air box style filter and just flat it out and use it instead of the screen.
but those are just ideas for now.
Old Aug 6, 2003 | 10:06 PM
evilxkid's Avatar
filters are over rated!
Old Aug 6, 2003 | 10:16 PM
T4eg's Avatar
that looks really good for being homemade. awesome job
Old Aug 6, 2003 | 11:24 PM
xJ.SLOTHx's Avatar
looks good...i want one for myself..haha
Old Aug 6, 2003 | 11:34 PM
summitracing order.
pipe part number:HOK-12270
discription:18 gauge, 2 1/2 in. diameter, 180 degree mandrel U-bend tubing
velocity part number: AVC-19000
discription:Velocity Stacks 5.5`` Dia. W/2.50`` Inlet Polished
thank me later ian
Old Aug 6, 2003 | 11:40 PM
xJ.SLOTHx's Avatar
good lookin' out
Old Aug 7, 2003 | 01:00 AM
if you want to see dyno results. i acccept paypal...
Modified by Lamchop0000 at 12:18 PM 10/9/2007
Old Aug 7, 2003 | 02:13 PM
StyleTEG's Avatar
I have the same velocity stack, but I just use a 2 1/2" rubber pipe connector to put it on the end of my CAI at the track.
I use mesh screen and foam as a filter.
If you are to go to a hardware store, you should be able to find foam air filters designed for A/C units. Its pretty cheap stuff. I basicly wrapped the screen first and the foam around it afterwards. (That way there is less likely of any foam coming loose and getting sucked into the intake.. but I don't see that happening anyways).
The idea is simmilar to foam filters like comptech use's for their shortram/icebox.
Old Aug 7, 2003 | 03:01 PM
thanks for the heads up styleTEG
Old Aug 8, 2003 | 07:35 AM
WAFFLES's Avatar
Default Re: (StyleTEG)
Try using Panty hose to filter it.
I sure hope it works...I've seen bad results on a dyno from removing the airbox completely and not running a filter. I'm not saying what you're doing wont work, just saying I hope it all goes well.
