check engine light off
Old Aug 5, 2003 | 10:24 PM
im_the_teacher's Avatar
Default check engine light off
01 civic salvage
check engine lite is off,run normal
check ground and power to light buld okay
wat could it be? wrong guage?
Old Aug 5, 2003 | 10:33 PM
mmuller's Avatar
Mad Scientist
Default Re: check engine light off (im_the_teacher)
hugh?
Bspec18's Avatar
whatz your problem ?
Old Aug 5, 2003 | 10:35 PM
Default Re: check engine light off (Bspec18)
you know the check engine light?
it won't come on......usually it should come on when u key on.....for 5 sec....
is on 01 civic
Old Aug 5, 2003 | 11:01 PM
mmuller's Avatar
Mad Scientist
did you check the bulb?
Old Aug 5, 2003 | 11:02 PM
Bspec18's Avatar
Look for the service pin connector and jump it. If it doesn't light on bad bulb.
jdm91ef
May 20, 2017 08:01 PM
aspire
Jun 28, 2010 10:49 AM
thunderboy
Mar 9, 2008 09:49 PM
dookieK9
May 26, 2007 02:31 PM
keprunited8
Jan 30, 2005 01:40 PM
