check engine lite is not on at all
Old Aug 5, 2003 | 10:21 PM
im_the_teacher's Avatar
Default check engine lite is not on at all
i check fuse (good)
chek computer ground for lite (good)
wat could it be?
anyone had this problem before
Old Aug 5, 2003 | 10:29 PM
Foozball26's Avatar
Default Re: check engine lite is not on at all (im_the_teacher)
yea i have the no check engine light problem too
sucks to have a perfect running car huh.
Old Aug 5, 2003 | 10:32 PM
jdmsol's Avatar
Default Re: check engine lite is not on at all (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">yea i have the no check engine light problem too
sucks to have a perfect running car huh.</TD></TR></TABLE>
LOL
Old Aug 5, 2003 | 10:33 PM
Default Re: check engine lite is not on at all (jdmsol)
oh yeah, u had one too.
did u fix it,,,,found the cause? wat is it?
dis on 01 civic .......
Old Aug 5, 2003 | 10:38 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
heres my chance...
Old Aug 5, 2003 | 10:44 PM
Default Re: check engine lite is not on at all (ciRcuitSi y0!)
hahahah *** you circuitsi
Old Aug 5, 2003 | 10:45 PM
UnrealSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_the_teacher &raquo;</TD></TR><TR><TD CLASS="quote">hahahah *** you circuitsi</TD></TR></TABLE>
LOL
Old Aug 5, 2003 | 10:59 PM
authentic plusONErandy's Avatar
Default Re: check engine lite is not on at all (UnrealSpeed)
hahahah what exactly is the problem with no check engine light? does it make u feel insecure that theres nothing wrong with your car?
Old Aug 5, 2003 | 11:12 PM
Daniel's Avatar
if it doesn't go on and the car's running okay then that's a GOOD thing.
Old Aug 6, 2003 | 01:23 AM
IWearMyKswiss's Avatar
New User
Default Re: check engine lite is not on at all (Daniel)
yea check engine light is only good in the sense that it tells you what the hell is wrong with your motor,...but technically the check light is a bad thing when on because,..well,..something is wrong with your motor
Old Aug 6, 2003 | 01:49 AM
Kamin's Avatar
Default Re: check engine lite is not on at all (WiDeBoDyEK)
WHAT THE **** ARE YOU TALKING ABOUT!??!?!?!?
the engine light only goes on when something is broken
Old Aug 6, 2003 | 01:53 AM
acuracing's Avatar
Most people post threads about how to get rid of engine lights.
This is a first, how to get my CEL to light up.
Foozball26's Avatar
Default Re: check engine lite is not on at all (Kamin)
guys its a joke, duh?
Old Aug 6, 2003 | 02:16 AM
nevin's Avatar
I think he was being serious...
Old Aug 6, 2003 | 05:16 AM
Daniel_san's Avatar
why do you think the light should be on ?
Old Aug 6, 2003 | 05:35 AM
Fuster_Cluck's Avatar
Default Re: (freezing-acid)
If the car is an 01 it may be under warranty still. Depending on if your mileage is over 36k or maybe you have the extended warranty.
So, when you turn the key to the "ON" position before starting the car the light doesn't come on for a few seconds then go off????????????
Have you done anything to the cluster? Done anything to the car?
Old Aug 6, 2003 | 05:36 AM
Zumo's Avatar
uhm.... check the bulb.
Old Aug 6, 2003 | 05:40 AM
dejay's Avatar
plug it in, cause this one time my lamp light wouldn't go on and it was just unpluged from the wall
Old Aug 6, 2003 | 06:09 AM
jetpilot's Avatar
i have the same q? When bridgind the ecu to set the timing, no cel comes on, maybe its the bulb, but may it be something else? Thnks
Should the cel come on when I first turn the key
Old Aug 6, 2003 | 06:19 AM
HondaIntegraLS's Avatar
Default Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot &raquo;</TD></TR><TR><TD CLASS="quote">i have the same q? When bridgind the ecu to set the timing, no cel comes on, maybe its the bulb, but may it be something else? Thnks
Should the cel come on when I first turn the key</TD></TR></TABLE>
It should.
Old Aug 6, 2003 | 07:29 AM
Looose_R's Avatar
Old Aug 6, 2003 | 07:34 AM
Foozball26's Avatar
Default Re: check engine lite is not on at all (b20bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20bastard &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
HAHAHAHAHAHAHAHAHAHAHAHAHA
best picture ever!
/right click...save as
Old Aug 6, 2003 | 07:48 AM
Marauder's Avatar
My check engine light came on once......
so I pulled over, popped the hood...and damn!!!
The engine was still there! check!
For some reason the light stayed on, but I didn't need to check anymore, the engine was still there!
Old Aug 6, 2003 | 08:20 AM
CTR_EK9's Avatar
Default Re: check engine lite is not on at all (Marauder)
I have the same problem my friend... it was a burnt resistor on the ecu. It took me 1 month to find it, i checked all the manuals, I post it here, I took it to 2 specialists but i found it myself. The resistor became blackand I coultn't read how Ohms was it so i fount some pictures from the internet I zoom them and i read the resistor.
I hope that it will help.
Modified by SiREG6 at 9:32 PM 8/6/2003
Old Aug 6, 2003 | 08:34 AM
Dr. EKology's Avatar
Dumbass.
