Oil pan leaking?
Old Aug 5, 2003 | 10:19 PM
Rhetoric's Avatar
Default Oil pan leaking?
It looks as if my oil pan gasket isnt doing its job. I have never taken it off before, why would it be leaking? It seems to be leaking a lot. Do you think factory warranty would cover it? My motor looks definitely modified, but do you guys know if might be worth asking the dealer to do it?
Modified by Rhetoric at 2:33 AM 8/6/2003
Old Aug 5, 2003 | 11:03 PM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: Oil pan leaking? (Rhetoric)
might as well take a shot and check with the dealer.
Old Aug 5, 2003 | 11:53 PM
jansenrw's Avatar
gasket.. mine did the same.. Jack up the car to be sure, wash everything with detergent then go for a hard strap.. make sure its the oil pan then consider replacing the gasket.. not too hard just afew 10 mm bolts!!!
good luck
Old Aug 6, 2003 | 05:04 AM
NINJA's Avatar
I just sprung a leak last week, I thought it was the from the filter but I replaced it and checked the gasket nothing...
I now am monitoring the oil pan after cleaning up the mess down there.
Where and what exactly is the "oil pan gasket"? Are you talking about the bolt on the bottom of the pan used to drain the oil?
Old Aug 17, 2003 | 12:27 PM
jdmcivicek's Avatar
Default Re: Oil pan leaking? (NINJA)
just do it yourself, its really not a big deal. it is a pain in the *** because my oil pan gaskets keep leaking! i wonder if it because im reving to 9300?
Old Aug 17, 2003 | 12:34 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJA &raquo;</TD></TR><TR><TD CLASS="quote">I just sprung a leak last week, I thought it was the from the filter but I replaced it and checked the gasket nothing...
Where and what exactly is the "oil pan gasket"? Are you talking about the bolt on the bottom of the pan used to drain the oil?</TD></TR></TABLE>
oil pan gasket is between oil pan and block
94 IntegraLS
May 7, 2013 11:42 AM
preludedriva
13
Aug 21, 2007 01:06 PM
00civicsiboy
Apr 20, 2007 08:27 PM
deconstruct
Jun 18, 2004 01:00 PM
yellowbulbs
Jul 17, 2001 01:12 PM
