What are the largest injectors you have idled on Hondata?
Old Aug 5, 2003 | 06:12 PM
Kwuaymaikrup's Avatar
Default What are the largest injectors you have idled on Hondata?
I am curious cause I will be trying to hit 600whp with my current setup and was wondering how large I can go with my injectors. I have Hondata 3b and don't really want to upgrade before I even get to use it. I am looking at some 1100cc+ injectors right now.
-Ryan
Old Aug 5, 2003 | 06:24 PM
ladysman's Avatar
Default Re: What are the largest injectors you have idled on Hondata? (Kwuaymaikrup)
I am using 800cc and it idles like stock. I have heard of people using 1000cc's like stock.
Old Aug 5, 2003 | 06:28 PM
Default Re: What are the largest injectors you have idled on Hondata? (ladysman)
Thanks!...anyone else?
Old Aug 5, 2003 | 06:53 PM
Pelican's Avatar
I have personally seen 8 1600s idle at 650 on a GSR. But that's with MoTeC
Old Aug 5, 2003 | 07:37 PM
Speed PHreak's Avatar
Default Re: What are the largest injectors you have idled on Hondata? (Pelican)
I idle 900cc'rs
Old Aug 5, 2003 | 07:46 PM
Default Re: What are the largest injectors you have idled on Hondata? (Speed PHreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote">I idle 900cc'rs </TD></TR></TABLE>
We are getting closer...
Old Aug 5, 2003 | 08:01 PM
SpeedDreamz.com's Avatar
My 1100's idle great with Motec M4. Cams create a slight lope but otherwise smooth.
Old Aug 5, 2003 | 09:21 PM
TEAMGENDAI's Avatar
You can do 96 lb at 60 psi easy do it all the time!! good luck. i have done 1 1200 cc engine!! they idle about 850 950 rpm
Old Aug 5, 2003 | 09:35 PM
uglyasscivic's Avatar
Default Re: What are the largest injectors you have idled on Hondata? (TEAMGENDAI)
The largest I have tuned are 750cc with a base fuel pressure of 55psi. I think 1100 or 1200 cc can be done.
Old Aug 5, 2003 | 10:05 PM
Default Re: What are the largest injectors you have idled on Hondata? (uglyasscivic)
Thanks alot guys....you have given me hope. What do you think would be best suited to my goal? I was gonna go with 1600's just to be safe but those are gonna be a bitch....
JAY
Mar 25, 2006 07:31 PM
BI8B
Mar 22, 2005 08:18 PM
tyflip2
Oct 26, 2004 05:27 PM
turborex
Feb 28, 2003 04:30 PM
