b18c1 stock bottom end bad with stage 2 cams ?
Old Aug 5, 2003 | 06:09 PM
ScottFern's Avatar
Default b18c1 stock bottom end bad with stage 2 cams ?
I am almost finished putting back together my engine.
Its a b18c1 with skunk2 stage 2 cams, skunk2 intake mani, and ctr n1 crank pulley.
Also, short ram, and a JDM ITR 4-1 header with 2.5" cat. Dunk exhaust
Am I making a mistake and going to put out worse numbers than if I had jdm itr pistons in my block ?
Will stage 1s put down better numbers than me ?
Old Aug 5, 2003 | 06:28 PM
igotyofire's Avatar
Default Re: b18c1 stock bottom end bad with stage 2 cams ? (ScottFern)
if u wanna keep bottom end stock with stage 2 cams, mill ur head and maybe go with a 2layer headgasket to raise ur compression, it will work but im guessing u wont be taking full advantage of the cam in which case u just just stick with stage 1 type cam
Old Aug 5, 2003 | 06:52 PM
ScottFern's Avatar
Default Re: b18c1 stock bottom end bad with stage 2 cams ? (igotyofire)
yeah, i know I am not using the cams to their potential, however I just wanted to make sure I am not going in the opposite direction. As long as I can see numbers just as good as stage 1s I am fine. I am going to do the bottom end next summer.
Old Aug 5, 2003 | 07:23 PM
dabomb's Avatar
[QUOTE=ScottFern]I am almost finished putting back together my engine.
would the jdm itr pistons bump up the compression enough to take advantage of those stage 2's?
Old Aug 5, 2003 | 07:25 PM
gsrvx's Avatar
New User
if you know ur gonna bump the compression up sooner or later....might as well get the stage 2s.
Rod
after nine30
Jun 19, 2007 06:16 AM
Greyghostgsrt
Sep 2, 2005 05:10 PM
10K2HVN
Jul 4, 2003 02:28 AM
PYITR821
May 19, 2003 06:48 AM
s2k420
Oct 12, 2002 06:40 AM
