Ebay Camber Kits - any good?
on a note, you can do camber adjustments with out the kits. If you use 1 mm washers on the bolts that anchor the control arms to the car (correct me if im wrong on the technical side) to push it out, you can adjust your camber at 1 degree per washer. I'm doing h & R race springs andi m going to try that first....cheaper....
they worked great for me...I also got the drilled /slotted rotors..a+++ I have had both on my car and no problems other than when they put on the camber kits they pulled to boot down by accident . I just jacked it up and used some plyers to fix it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">well, i lost the bid on her teg, but i won for the prelude, 10.50!!!!! so we'll see if it is even real, then how good they are.</TD></TR></TABLE>
get it installed?
get it installed?
eMpAtHy
Apr 17, 2009 11:16 AM
let me know....
