89 crx si motor swap to zc motor how do i wire the distributor?
Old Aug 5, 2003 | 04:58 PM
mustangracer1969's Avatar
Default 89 crx si motor swap to zc motor how do i wire the distributor?
i put the motor and bolted it to the tranny. now how do i hook the distributor up because they have almost the same color codes and i spliced them to matcha and i have two odd ball wires that don't match so i connected one and the car starts but it won't go over 3500 rpms also i still have the crx comp. Please help
Old Aug 5, 2003 | 05:03 PM
TrickHonda98's Avatar
Default Re: 89 crx si motor swap to zc motor how do i wire the distributor? (mustangracer1969)
sounds pretty weird, try a few different combinations. When I hooked up my '95's dist. a few wires where at different colors, and it works. ONE MORE THING:you might want to change your user name. not too many people in this forum like mustangs.
Old Aug 5, 2003 | 05:20 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
try this: http://www.dmoore.com/crx/zc-phase3.htm
taken from here: http://www.dmoore.com/crx/zc.htm
also a good link: http://www.thezcresource.com/html/zcbook.html
Old Aug 5, 2003 | 06:53 PM
joey1320's Avatar
Default Re: 89 crx si motor swap to zc motor how do i wire the distributor? (88DXCRX)
same ? I posted in a different thread, was your A6 motor in bad condition?
Why go for the ZC???
If your original motor was in good condition, just high miles, then why not rebuild it with the money you used on the ZC?
Old Aug 6, 2003 | 08:16 AM
DJ_SaNdOz's Avatar
The wires on the harness side will look different due to age. The wires will match color to color, but on the harness side the white wires may look almost pink/oraneish, the others should match up relatively easily. Those web sites confused me & didn't work- once I did it color to colr myself it worked fine- the hardest part will be teh 2 white wires b/c thre is no distinguishing difference between them. HTH
JDMproblem
Mar 6, 2009 11:38 AM
h22_crx
Sep 10, 2005 08:51 PM
HaRd KoRe CRXtasy
Sep 3, 2004 05:15 PM
Cre
Jul 23, 2003 09:43 PM
kHoA DoGG
Feb 18, 2003 08:50 PM
