blance shaft thought....possibly talked about before?
Old Aug 5, 2003 | 04:44 PM
spoolinlude's Avatar
I live under a rock
Default blance shaft thought....possibly talked about before?
I was reading old posts about balance shaft eliminations and so on and I thought to my self...... WHY NOT JUST LEAVE THE BELT OFF????? I don't see where the problem would be in doing that, and wouldn't it have the same effect as removal, excluding the weight issue?
Old Aug 5, 2003 | 07:03 PM
del_parker's Avatar
Default Re: blance shaft thought....possibly talked about before? (spoolinlude)
that pretty much sums it up. but the plugs clean up the appearance and blocks off the oil.
Old Aug 5, 2003 | 07:10 PM
laughinxxx's Avatar
New User
Default Re: blance shaft thought....possibly talked about before? (del_parker)
Who sells the plugs and caps?
Old Aug 6, 2003 | 12:22 AM
Furry in your eye
Guest
Posts: n/a
i thought thats what most people were doing.. .just taking the belt off
i ran my f22 w/a balancer belt for about 20k miles, no problems cept for a cracked radiator and now warped head... h22 time w00t
Old Aug 6, 2003 | 01:07 PM
I live under a rock
Default Re: blance shaft thought....possibly talked about before? (Furry in your eye)
but did the balance shaft being disconnected cause that?
Old Aug 6, 2003 | 10:57 PM
Furry in your eye
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">but did the balance shaft being disconnected cause that?</TD></TR></TABLE>
nope... and guess what.. the balancer belts are comin off my new motor soon as i get it
Old Aug 7, 2003 | 03:30 PM
I live under a rock
so u need a re-sized belt then right..... since u need to drive the oil pump still
Old Aug 7, 2003 | 04:03 PM
clendaniel's Avatar
The oil pump's driven directly off the crank...you can just pull the belt. I used Hondaddict's billet plugs and eliminated the shafts entirely but it's the same basic effect.
--Ian
Old Aug 7, 2003 | 04:30 PM
SKDRCR's Avatar
Default Re: blance shaft thought....possibly talked about before? (clendaniel)
1. How does doing this benefit your car
2. How many tenth's of a sec will you improve by doing this
3. How will this affect your car if you drive on the for long distances
Old Aug 7, 2003 | 05:18 PM
I live under a rock
OK then i think i confused my self....... the oil pump gear is on the timing side on the right correct?........or, where the hell is it...... its been a long day and i'm confused
Old Aug 7, 2003 | 07:59 PM
clendaniel's Avatar
nope, the oilpump gear slides over the crank. The gear you're thinking of is simply driving the rear balance shaft...the rear shaft runs at 2x the engine speed.
As to the benefits...reducing rotating mass. Anytime you reduce the rotating mass you free up horsepower. For the doubters out there my engine runs smoothly and you'd be hard pressed to tell my sleeved/JE/Pauter/no-balance-shaft motor from a stock one even with ES inserts.
--Ian
Old Aug 7, 2003 | 08:23 PM
poison's Avatar
Here ya go:
https://honda-tech.com/zerothread?id=550285
Old Aug 8, 2003 | 02:09 PM
I live under a rock
Default Re: blance shaft thought....possibly talked about before? (poison)
alright so not to sound like an idiot here, where's the oil pump gear at? is it on the timing side behind the first oil seal on the crank or is it on the back side(tranny side)?.........
Old Aug 8, 2003 | 09:41 PM
clendaniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">on the timing side behind the first oil seal on the crank</TD></TR></TABLE>
Old Aug 9, 2003 | 08:41 PM
I live under a rock
ah ha thanks...... you finish tom's supra yet ian..... i ain't talked to him in a while
Old Aug 9, 2003 | 08:43 PM
I live under a rock
can i get to it w/o takin out the crank?
Old Aug 10, 2003 | 09:34 AM
clendaniel's Avatar
Haven't started his supra yet...trying to get some of the other cars outta here first. I'll probably get it in here next week and start working on it...unfortunately my new job is alot of travel so he's gotta be patient!
You can pull the oil pump without pulling the crank, you just need to remove the timing/balance shaft components and about a dozen 6mm bolts. It should be doable with the motor in the car but won't be fun!
--Ian
Old Aug 10, 2003 | 04:54 PM
I live under a rock
ehh the motor's out so no biggie......... yeah i talked to tom today-- actually i was standing next to him when you called n said you would do it this week for the show saturday...... let me know if you need a hand....... m right around the corner....
1sickef9
Nov 24, 2009 07:18 AM
98hondalude
Sep 24, 2007 10:42 AM
rasta420
Jan 3, 2007 10:05 AM
05member y0
Nov 16, 2005 09:36 AM
