Cold AC vs. Header question
Old Aug 5, 2003 | 03:52 PM
slow-n-low's Avatar
Default Cold AC vs. Header question
I'm planning on putting a header on my f22. The AC line is really close to the manifold. Has anyone ran into problems with this? Should I thermal wrap the ac line or header? Or will it not affect it?
I don't want to take the AC out.......TN summers are hot and I'm a fat guy, and heat and fat guy dont mix
Let me know.....Thanks.
Modified by slow-n-low at 12:47 AM 8/6/2003
Old Aug 5, 2003 | 08:38 PM
slow-n-low's Avatar
Default Re: Cold AC vs. Header question (slow-n-low)
Any help??
Old Aug 6, 2003 | 12:14 AM
iam7head's Avatar
how close? touching?
dont let the ac line touching the manifold or it will catch on fire.
Header wrap seem to be a better solution.
Old Aug 6, 2003 | 08:24 AM
ApexiAccord's Avatar
if it is really close, then i recommend getting the AC hoses wraps the DEI makes. it can be ordered through jegs or summit racing. das wat the turbo guys use so that there ac line wont get to hot and bust on them, due to the heat from the turbo.
Old Aug 6, 2003 | 03:40 PM
YeuEmMaiMai's Avatar
Default Re: Cold AC vs. Header question (ApexiAccord)
did you take off the heat shield? if so put it back on my ac lines are not close to my heata shield at all. Do you have the original lines or are they replacements?
my lines are closer to the radiator than the heat shield.
Old Aug 6, 2003 | 04:12 PM
slow-n-low's Avatar
Default Re: Cold AC vs. Header question (YeuEmMaiMai)
The car was in a lil skirmish with a Tracker (Dang Chevys .....sorry if youre a chevy person). Some front end cosmetic damage. But everything is back to spec. The ac line isn't touching. all 94-97s are like this, just wondering if anybody had a problem with it after putting on a manifold.
Just a stock setup......when I had a header, I want to make sure the ac wont be affected.
Old Aug 6, 2003 | 05:20 PM
CaptainObvious's Avatar
There is plenty of room between my heat shield and the ac line. But common sense tells me that a cold line next to a hot header is good cause for thermal wrapping .
Old Aug 6, 2003 | 05:49 PM
dantastic's Avatar
i had a greddy header on my accord for 80kmi+. never a prob with the ac
Old Aug 6, 2003 | 07:57 PM
h22lx's Avatar
its fine. if they do touch, take out the ac. just robs hp anyways
Old Aug 7, 2003 | 12:59 PM
Default Re: (h22lx)
he does not want to take the A/C out that is why I recommended that he put the heat shield back on.
Old Aug 7, 2003 | 09:11 PM
slow-n-low's Avatar
Default Re: (YeuEmMaiMai)
Thanks for the help fellas. I'll probably get a 4-2-1 and keep an eye on the line. I'll probably thermal wrap it anyways.
Dark_Teg
Mar 5, 2009 05:33 AM
Sanj
Sep 21, 2005 10:47 PM
Hybrid Invasion
Jan 29, 2004 05:41 PM
boostdGS
Jul 21, 2003 12:31 PM
