92-95 auto manual swap mount
I'm doing an automatic to manual conversion and I need the transmission mount. I've called both place racing and HCP and its on backorder at both places. Does anyone know if there are other companies that make a mount for this?
which swap is it? for an h22 we had to cut the auto mount, and weld on a 5spd. The 5spd mount from honda is only 22 bux and its not that hard to do
just go to honda and buy a new weld on mount for your car. For $30 and about 30 mins of work you can have yourself a mount which some honda engineer probably spent many hours designing. I've done this myself and it work just fine. IMHO, don't mess with an aftermarket mount when you can use what was designed for your car by the factory
I got one from Place Racing, Mine woks fine expensive as hell though almost 200 bleh but its polyeurethane and works:
http://cherrychaser.net/pics/2...6.JPG
jdmshit.com sells HCP mounts....which are on backorder.
I'm putting in a JDM B16.
I know i could put in a new oem mount but I just painted my engine bay thinking i was going to get an aftermarket mount easily.
I guess i might just have to suck it up and messup a beautifual paint job
The difference between AFTERMARKET and OEM is that the Aftermaket is the MOUNT repositioned to make use of the existing bracket and the OEM thing for 30 bux is the Bracket so that you can use the OEM Mount.
The OEM way is the Cheaper way and will not disrupt the Geometry that was intended
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG »</TD></TR><TR><TD CLASS="quote">The difference between AFTERMARKET and OEM is that the Aftermaket is the MOUNT repositioned to make use of the existing bracket and the OEM thing for 30 bux is the Bracket so that you can use the OEM Mount.
OEM mount is cheaper but some people are afraid of welding the new mount on. More of a hassle for some. Aftermarket mount just drops right in.
</TD></TR></TABLE>OEM mount is cheaper but some people are afraid of welding the new mount on. More of a hassle for some. Aftermarket mount just drops right in.
let me see if i can get u the number, if not u will probably have to go down to the dealer, and point to the part u are talking about. They dont know ****. I know its part of the sub frame, or frame.
cloud4571
Sep 29, 2012 03:25 PM
92lxsleeper
Jul 12, 2009 07:50 PM
stackz
Nov 15, 2006 01:04 PM
gsp ej1-em1
Feb 26, 2006 06:52 AM
