60k mile maintenence for integra gsr help?
Old Aug 5, 2003 | 03:39 PM
JadeDM's Avatar
Default 60k mile maintenence for integra gsr help?
Im looking to get my 60k mile maintainence check done, can anyone give me a list of whats needed to be done, fluids changed, valve adjustment, everything that should be covered and also a price i should be looking to pay not going to the dealership?
thanks guys
Old Aug 5, 2003 | 04:49 PM
GreenGSR311's Avatar
Default Re: 60k mile maintenence for integra gsr help? (JadeDM)
I don't have the manual infront of me to tell you all the things that need to be done, but I was quoted $285 from a honda repair shop (not dealership). It seems like a fair price.
Old Aug 5, 2003 | 04:56 PM
Havokmkr's Avatar
Default Re: 60k mile maintenence for integra gsr help? (GreenGSR311)
Basic tuneup(includes valve adjustment), tranny and coolant flush, check fluids, ignition system, brake system, srs system, check general condition. Basically short of putting a new water pump and timing belt in, you just have to get everything checked out. You can do most of that yourself and just have a shop do the tranny flush and the valve adjustment(if you don't think you could do it). It's also nice to have a shop check the general condition of everything so you know how your car's doing.
Old Aug 5, 2003 | 05:51 PM
JadeDM's Avatar
i know i saw some people post a list before of what needs to be done... anyone?
Old Aug 5, 2003 | 07:51 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (JadeDM)
Part Description Part Cost
Air filter $ 22.50
Engine oil $ 10.50
Oil filter $ 6.60
Spark plugs $ 14.40
Timing belt $ 57.50
Total Estimated Parts Cost $ 111.50
Labor Action Item Labor Cost
Replace Air filter $ 2.67
Clean Antenna mast $ 5.34
Inspect Brake lines, hoses & connections $ 1.06
Inspect Brakes $ 16.02
Inspect Cooling system hoses & connections $ 5.34
Inspect boots & seals Drive axles $ 5.34
Inspect/adjust Drive belt(s) $ 1.60
Change Engine oil $ 10.68
Inspect Exhaust system $ 2.67
Inspect Fluid levels $ 2.67
Inspect Fuel lines & hoses $ 2.67
Inspect Hinges, locks & latches $ 2.67
Check operation Lights & controls $ 5.34
Replace Oil filter $ 5.34
Inspect Parking brake $ 2.67
Replace Spark plugs $ 26.70
Inspect Steering gearbox $ 5.34
Inspect Suspension $ 5.34
Inspect Tie rod ends $ 2.67
Replace Timing belt $ 133.50
Inspect Underbody $ 2.67
Inspect Valve clearance $ 2.67
Rotate Wheels & tires $ 16.02
Total Estimated Labor Cost $ 267.00
Total Estimated Costs
Total Estimated Parts Cost For Your Area $ 111.50
Total Estimated Labor Cost For Your Area $ 267.00
Total Estimated Cost (excluding tax)* $ 378.50
http://www.edmunds.com/mainten...Acura*
CPTN
May 11, 2010 09:01 AM
integra123
Mar 31, 2006 06:56 PM
Sliminem
Mar 6, 2004 12:36 AM
nrusso14
Oct 27, 2003 09:10 AM
tb_pimpjuice
Oct 18, 2003 02:58 PM
