Starting issues
Old Aug 5, 2003 | 03:24 PM
fsck3r's Avatar
Default Starting issues
I went out to my hatch the other day and tried to start it and it wouldnt start. There was a loud clicking noise coming from under the hood where the starter is.
I checked my grounds and all but still no start. I decided to push start it and pop the clutch and it worked. I drove it around the block and the shut it off and it started fine and it continued to start fine for the next couple days. I went out today and tried to start it but same loud click, then it started, I shut it off and tried again and it clicked loud once then started. Any ideas what it could be and how to fix it?
Old Aug 5, 2003 | 03:27 PM
poison's Avatar
Default Re: Starting issues (fsck3r)
I would take off the starter and bench test it. Make sure there is no corrosion on the starter power cable and no corrosion on the battery terminals.
If all else fails, the solenoid on the starter is faulty and the starter will need to be replaced.
Old Aug 5, 2003 | 03:56 PM
fsck3r's Avatar
Default Re: Starting issues (poison)
top
Old Aug 5, 2003 | 03:59 PM
Stupid Ass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsck3r &raquo;</TD></TR><TR><TD CLASS="quote">top</TD></TR></TABLE>
Why? Poison told you what anyone else is going to tell you. Have it tested.
Old Aug 5, 2003 | 04:03 PM
94si94cx's Avatar
Default Re: Starting issues (MooreVTEC)
It could be flywheel related. I replaced my starter and double checked all connections and voltages. I've still yet to find my problem.
Old Aug 5, 2003 | 04:10 PM
fsck3r's Avatar
Default Re: Starting issues (94si94cx)
Does your make the same clicking noise?
Old Aug 5, 2003 | 05:03 PM
94si94cx's Avatar
More than likely the clicking sound is the starter engaging. Is the click all your hear?? I hear a metal shen kind of sound spinning as well as the click.
Old Aug 5, 2003 | 05:08 PM
TrickHonda98's Avatar
someone needs a valve adjustment? check the valves. it may sound odd, but just check them anyway.
Old Aug 5, 2003 | 05:16 PM
94si94cx's Avatar
Default Re: Starting issues (TrickHonda77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrickHonda77 &raquo;</TD></TR><TR><TD CLASS="quote">someone needs a valve adjustment? check the valves. it may sound odd, but just check them anyway.</TD></TR></TABLE>
Are you talking about me? It only does the metal sheen sound when the clutch is pushed in. If it was a valve issue, it would always do it.
Old Aug 5, 2003 | 05:40 PM
fsck3r's Avatar
Nah just a loud click, Im going to check it out this weekend, Whats the difference between Mitusba and a nippondenso also?
Old Aug 5, 2003 | 05:43 PM
94si94cx's Avatar
Not sure. I would suggest pulling yours off and taking it to the parts store.
Nippon = Japan (just a side note, completely irrelavant)
prelude2001h22a
Nov 22, 2014 02:04 PM
JPerkMr954
Jun 9, 2013 08:51 PM
eskerley
Apr 21, 2008 08:01 PM
Fatboy1985
Dec 26, 2003 02:38 AM
Goy091
Jul 7, 2002 06:09 AM
