how far are the bumpstops?
Old Aug 5, 2003 | 03:12 PM
Jason C SBB's Avatar
Default how far are the bumpstops?
With the stock suspension, how far does the suspension compress before the bumpstops are touched? I have a '97 HX.
Old Aug 5, 2003 | 04:04 PM
VTECorona's Avatar
Default Re: how far are the bumpstops? (Jason C SBB)
This is kind of a blunt answer but I'd say just about all the way. The purpose of them is to absorb some of the shock when you bottom out.
Old Aug 5, 2003 | 05:38 PM
dfoxengr's Avatar
Default Re: how far are the bumpstops? (VTECorona)
what would be the reason in knowing this...
Old Aug 5, 2003 | 05:46 PM
Mohudsolo's Avatar
Default Re: how far are the bumpstops? (hybridvteceg)
Actually the bumpstops are about 1 5/8" tall and tapered. They will act as a progressive spring when they hit. That allows Honda to use a softer spring for ride then hit the long stop as a stiffer spring. Not sure how much upward travel before they hit though.
Old Aug 5, 2003 | 06:48 PM
GZERO's Avatar
His question is pretty interesting since a GOOD suspension needs to have the bumpstops well calculated to work well (at least on streets).
not sure about honda's but most of the cars have the bump stops that takes like 30-40% of the suspension total travel.
pkolaboy
Apr 16, 2008 08:49 AM
Tyson
Dec 25, 2005 04:40 PM
itr1236
Mar 6, 2003 09:13 PM
Matt Groove
Oct 15, 2002 07:16 AM
Ricehornet
Jun 27, 2001 03:15 AM
