89 CRX HF ZC swap, whats needed to be done ?
whats needed to be done on this swap ?? axles ? tranny ? ecu ? any wiring etcc . if someone can give me a website How-To or somethign that'd be great. thanks
The HF is already MPFI correct? And doesn't it use the same axles as the Si? I may be wrong on that. Anyway, you would need motor & ECU at a minimum, I would definately suggest getting either the ZC or Si tranny b/c that HF tranny would be no fun IMO. For ECU you can use teh PM6, PM7, or PG7
Axles are different, BUT you can use you can use your HF axles if you keep the HF hubs, but if you swap out to a b series, you need to upgrade to bigger hubs, dx or si or integra or some upgrade, but hf is too small.
pdiddyparsons
Feb 20, 2003 01:04 PM
