For a JDM OEM sheetmetal Teg front end...
Old Aug 8, 2001 | 03:33 PM
moss's Avatar
Default For a JDM OEM sheetmetal Teg front end...
Is there something you must cut out? Like a radiator support.... and weld in the JDM one? I read that you had cut something out, don't remember what board I read it on though. . If you do, is there anyway to get around cutting it out? I'm looking into getting a '97 Teg w/ some damaged to the front (fenders) and I'm trying to find out how much of a hassle the JDM front end would be.
[Modified by moss, 12:35 AM 8/9/2001]
Old Aug 8, 2001 | 03:56 PM
SagaGSR's Avatar
Default Re: For a JDM OEM sheetmetal Teg front end... (moss)
you have to usdm radiator support is different from the jdm one..its spot welded..you just have to drill into the spot welds and it'll come off...
98+ models have the same radiator support as the jdm one..but the bumper support and upper bar support is different...(most jdm conversion kits come w/ a jdm radiator support, bumper support and upper bar support so you might as well switch em all out at the same time)
Nikademo
Jun 24, 2010 06:14 PM
99DCteG
Oct 21, 2006 12:18 AM
98lsskunk
Welding / Fabrication
Apr 20, 2005 06:52 AM
jdm phantomx
Jan 16, 2005 02:34 PM
Blazeone
Mar 12, 2004 08:44 AM
