Need D16 help.
Old Aug 5, 2003 | 12:13 PM
SignNameHere's Avatar
Default Need D16 help.
Lol let me start off by saying I don't want a swap or F/I. I'm still paying off my civic, paying for school and other bills but I still want to fiddle around with the engine just for kicks, not really looking for speed cause I use my dad's 325 IS when i wanna race.
Lol But I do need help because with my stock LX engine I have already put AEM pullies, AEM cam gear, Injen CAI, Dc 4-2-1 headers, took he cat out with a 2/14 custom menderal bend exhaust.
All im looking for now is a cam shaft, throttle body *cause it still points up*. I was wondering a good website to find those things and other internal's i need to help my civic. It's also an automatic bare in mind.
Flames, Opinions and advice welcomed. Thanks in advance
Old Aug 5, 2003 | 01:10 PM
dragonhaven2001's Avatar
Default Re: Need D16 help. (SignNameHere)
You sure your LX has a D16 engine and not a D15? I had an LX and did a D16z6 swap to get the engine. Edlebrock has a nice throttle body but I think it's like 300 dollars. It's got some bling though!
Old Aug 6, 2003 | 04:49 AM
Mr Hammond's Avatar
a/k/a Jomo
I'd put the money towards school and pay it off faster. Or save it for when you break pop's bimmer.
Old Aug 6, 2003 | 11:29 AM
barto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SignNameHere &raquo;</TD></TR><TR><TD CLASS="quote">
a new throttle body isnt gonna help with the pointing up thing. ud have to get a new intake manifold
Old Aug 6, 2003 | 11:33 AM
Default Re: Need D16 help. (EKHatchRacer)
Lol oops yea mistake gonna replace it with a Skunk 2 manifold and a STR 65mm throttle body. My engine is a D16y7 I believe..
Old Aug 6, 2003 | 12:16 PM
sohc_boy's Avatar
r u still running the y7 tranny if so get an ex that will make a huge difference. people that have stuff for the y7 that i can think of are gude, delta, and exospeed off the top of my head, these are all regrinds. talk to exospeed marc for help on the d-series.
Old Aug 6, 2003 | 01:23 PM
Default Re: Need D16 help. (sohc_boy)
Ex tranny? Really...hmm any reason why? just a little curious. Aight i'll be sure to talk to him
Old Aug 6, 2003 | 06:33 PM
infinatenexus's Avatar
the ex tranny has a lower final drive ratio
Old Aug 6, 2003 | 07:35 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Need D16 help. (infinatenexus)
Ok I think you guys are thinking he's running a 5-speed. He's auto. The dx and ex auto's are pretty much the same thing.
Old Aug 6, 2003 | 07:52 PM
Default Re: Need D16 help. (Mr Milano)
Lol thanks...I was wondering why they suggested it. So there is no difference.? Lol thanks!
Old Aug 7, 2003 | 05:00 AM
sohc_boy's Avatar
didn't know u were running an auto my bad for not reading. if u have the money consider getting a torque converter that will help alot.
Old Aug 7, 2003 | 07:00 AM
TrboInteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SignNameHere &raquo;</TD></TR><TR><TD CLASS="quote">Lol oops yea mistake gonna replace it with a Skunk 2 manifold and a STR 65mm throttle body. My engine is a D16y7 I believe..</TD></TR></TABLE>
That throttle body sounds a little large and expensive. I, personally would try a used 60mm b-series first before spending that kind of money. Also, you might want to try some d16a1 rods and pistons. The rods are stronger and the pistons will bump up c/r.
Old Aug 7, 2003 | 08:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">didn't know u were running an auto my bad for not reading. if u have the money consider getting a torque converter that will help alot.</TD></TR></TABLE>
Oh, you mean get my torque converter worked on? I thought all auto's already have one.
Old Aug 7, 2003 | 08:15 AM
Default Re: Need D16 help. (TrboInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrboInteg &raquo;</TD></TR><TR><TD CLASS="quote">
That throttle body sounds a little large and expensive. I, personally would try a used 60mm b-series first before spending that kind of money. Also, you might want to try some d16a1 rods and pistons. The rods are stronger and the pistons will bump up c/r.</TD></TR></TABLE>
will the stock sensors and everything work on it? I realize that my old throttle body had the throttle body cable on the right side, since if i get a new intake that will be laying flat , will i be able to use the same cable? I know it sounds stupid i just figured i'd have to prolly get a long one, prolly of a EX.
Old Aug 7, 2003 | 09:55 AM
TrboInteg's Avatar
I honestly don't know if you would be able to use your old cable. I'm going to guess and say no because that is the worst case scenario. And if you can't, a new cable from honda is only about $15(that's what I paid for a new ITR cable).
Old Aug 7, 2003 | 10:12 AM
Oh, true true...just a new EX cable will do?
Old Aug 8, 2003 | 06:03 PM
the onlt TB you can use on your motor is the one it came with it. The Y7 has a differant IACV plug that the other Honda TB's. IF you convert over to a EX ECU, and wirinh harness, then you will be able to run a B series TB.
You can easily convert over to the Y8 intake manifold. TO do it you need to swap your Y7 throttle rotor, and spring for the one on a Y8 TB. Your stock throttle cable will work, just don't use the mount on it that is located on the valve cover
98.4DR.EK.D16
Dec 15, 2012 08:28 PM
AccordSleeperZzZ
Jul 10, 2006 12:56 PM
ftwlucky13
22
Mar 20, 2006 12:53 PM
Halive
18
Sep 19, 2001 08:15 PM
