Grinding down intake valve guides
Old Aug 5, 2003 | 01:58 AM
fox297's Avatar
Default Grinding down intake valve guides
Has anyone done it or is it a bad idea? I'm very tempting, but still a bit chickenish.
Old Aug 5, 2003 | 05:36 AM
tk's Avatar
tk
Default Re: Grinding down intake valve guides (fox297)
Not worth the gains for what you loose in guide strength and stability of the valve at high rpm, IMO anyways
Old Aug 6, 2003 | 08:57 AM
fox297's Avatar
Default Re: Grinding down intake valve guides (tk)
Anyone tried it before?
Old Aug 6, 2003 | 11:03 AM
gtpilot's Avatar
Yes, I have done it to numerous race heads over the last ten years...with the original Honda guides as well as aftermarket bronze guides. I have not had to change any of the guides out yet and some have been in service for a long time. These motors regularly see revs above 8000 RPM and approach 9000 at some races.
I have just done it to a street motor (D16), but have not lit it up yet. It will be my daily driver - I just wanted some more long term wear information and figured this was the easiest way to get it.
Kirk
Old Aug 6, 2003 | 12:47 PM
fox297's Avatar
Default Re: Grinding down intake valve guides (gtpilot)
Would switching to bronze guides make it stronger. I don't really care about reliability issue, but I do want to rev to 10k. If the motor can last for 10k mile, I'll be real happy.
Old Aug 7, 2003 | 08:34 AM
gtpilot's Avatar
Just use the original factory guides...they are pretty damned hard. When I am porting and have to grind the factory guides it takes a lot longer than the bronze guides. I don't think you will have any problem getting 10K miles out of them.
Kirk
Old Aug 7, 2003 | 09:54 AM
skribblah's Avatar
larry from endyn also tapers the valve guides.
Old Aug 7, 2003 | 10:09 AM
gtpilot's Avatar
Default Re: Grinding down intake valve guides (skribblah)
Tapering is a little harder to accomplish than grinding them down to the roof of the intake runner - especially if you don't press the guides out and turn them down on a lathe. It does have the advantage that you have more support for the valve as the length of the guide can remain the same.
Kirk
Old Aug 7, 2003 | 11:50 AM
fox297's Avatar
Thanks for the encouragment, I'm going to do this for sure! Hi velocity port, here I come!
patrick_yi_82
May 14, 2010 08:30 PM
85_305
21
Jan 12, 2009 01:51 PM
neofreak
Jul 1, 2007 12:04 PM
eightvalver
Sep 3, 2004 09:38 AM
raser5050
Oct 20, 2003 12:29 PM
