0k fellas tein or eibach springs on a eg????
redoing my suspension, what kind of springs do you guys prefer?
______________________
TeAm cIty LimIt (chicago)
-thanks n advanced for the advice.......
"oNly Fo0ls rUsh inN"
Um...depends on your budget...if you have the $$ go with tein...otherwise eibach's will do just fine
While we're on the topic of suspension, I got a quick q myself. I wanted to know how much of a drop I would get on Integra prokit springs (rated at 1.3" drop) on a 95 lx 4dr (weighs like 2376 lbs).
I figured I'd go for the Integra spring rates for better handling, and if it doesnt drop as low, that'd be great... b/c i live near shitty roads and this is my daily driver.
I am running eibach sportlines on my 94 hatch with tokico blues. The thing is tho, they are from a 94-01 integra. They fit fine, but the ride is horribly stiff. The whole car shakes when I fit bumps and anything more than a crank in the road, kind of unpleasant.
I dont know if I just need civic springs, or cut the bumpstops ? OR what ?
i have eibach sportlines on my hatch, the drop is perfect, and they ride like near stock. i LOVE them. eibachs are the best out of the springs i've had ( skunk2, H&R, Eibach )
if u look at the springs ull notice that the ones on the coilover s are not wound the same as the individual springs of the tein SS s or eibiach Prokit and Sportlines
this would indicate they re not progressive style springs and have a constant stiff ride rather than stiffinging up while being compress d
I just figured it sucks if you buy lowering springs and your ride height isn't even for whatever reason. At least with sleeve coilovers, you can correct it.
Eibach Sportlines w/ Koni Yellows.
