automatic to manual swap.....please help!!!!!!
Old Aug 4, 2003 | 06:12 PM
Eibach95Civic's Avatar
Community Builder
Default automatic to manual swap.....please help!!!!!!
ok i have a WHOLE 1995 coupe ex that has been totaled out, and it has manual transmission, i just bought a 93 dx hatch and it has an automatic transmission, i have all the parts needed, is their any step-by-step way to put this in??i have searched but no real info on putting it in just parts needed...ohh yah i will take pics and show a step-by-step how to, while in process of completion. thanx
Shane
Old Aug 4, 2003 | 06:19 PM
Smith Wise's Avatar
Default Re: automatic to manual swap.....please help!!!!!! (Eibach95Civic)
the easiest part is just bolting things on
the hardest part is putting the damn pedals on, removing the auto shifter bs, rewiring for the reverse lights, rewiring so you can get the key out, everything else is easy
edit: should take two days, 8 hours a day
Old Aug 4, 2003 | 06:29 PM
Community Builder
Default Re: automatic to manual swap.....please help!!!!!! (Jswpstdoff)
for the puttin the petals in? like is the drilling invloved, or what..detail man
Old Aug 4, 2003 | 06:39 PM
Community Builder
ok i have see this before though man, like is their anypost that anyone knows about on how to do this...me and my brother have the confidence, just we need a little more than a helms, and two other civics of ours to look off of
Old Aug 4, 2003 | 06:41 PM
Aaron Taylor's Avatar
I swapped my car to manual. If you have all the parts it will be a lot easier. You can get around the re-wiring by swapping the underdash harness out. Just IM with your questions I'll help you out. There's a lot more that goes into to do it the right way.
Old Aug 4, 2003 | 06:53 PM
Community Builder
Default Re: automatic to manual swap.....please help!!!!!! (Aaron Taylor)
hey thanx man...i soon will have a post to help others out...gotta love honda-tech
Old Aug 4, 2003 | 11:00 PM
salbaje's Avatar
i have done plenty of auto to manual swap all will be direct bolt in with the exception of drilling 2 holes to hold up shiftlinkage. And possibly rewelding or buying an auto to manual top tranny mount
Old Aug 5, 2003 | 05:13 AM
realblag's Avatar
you got everything you need right there. just pay attention to the little stuff like the flywheel bolts and the driveplate bolts are different. you might as well do the engine swap while you're at it. that d16z6 will make a big diff. you'll need to drill two little holes in the floor for the shifter mount but you can see the marks in the floor where they should be. you also need to get the top trans mount outta the ex and weld it in. everything else is bolt-up.
eg_ruoner364
Jun 18, 2008 12:04 PM
ShortKyle
Oct 26, 2006 06:24 AM
KingPin326
Sep 21, 2006 08:16 AM
joshcivic00
Jul 11, 2005 12:27 PM
