SHIFTER WONT GO INTO GEAR
Old Aug 4, 2003 | 05:04 PM
FROST's Avatar
Default SHIFTER WONT GO INTO GEAR
Hopefully somone can help me figure this out. I currently have a 92 integra and sometimes while I'm driving when I shift out of gear I can't get the shifter back into any of the gears. I've replaced the shift linkage bushings but still no luck. Someone told me that it could be my clutch but there weren't any signs of my clutch slipping before this started happening. Could this be a transmission problem? Any insight would be appreciated
Old Aug 4, 2003 | 05:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: SHIFTER WONT GO INTO GEAR (FROST)
I had about 135K miles on my original clutch on my car, but it didn't really slip or anything. One time I rode out 2nd gear to redline, and after that it got really hard to shift. People suggested one of the springs in the clutch got dislodged, and sure enough when I took it off, I found pieces of metal from the clutch disc near the springs had broken off. It could also be a problem with the fingers on the pressure plate springs.
Old Aug 4, 2003 | 05:15 PM
Brett's Avatar
Default Re: SHIFTER WONT GO INTO GEAR (PatrickGSR94)
Same thing happened to me. Your clutch won't slip at all but if the springs are fucked up your clutch won't fully disengage keeping your shifter from going into gear. Seems to be a pretty common proglem on tegs.
93delslow315
Feb 5, 2010 07:08 AM
ToryluvshisDA
May 1, 2008 01:59 PM
Jer'rome
May 26, 2004 02:34 PM
acuracy90
Aug 27, 2003 03:58 PM
Kevins2k
Jun 11, 2003 10:56 PM
