Flat top eibach springs....such a thing??
Old Aug 8, 2001 | 10:32 AM
Petah's Avatar
Default Flat top eibach springs....such a thing??
I was told that eibach made flat top springs for use with coilover applications....can anyone veryify this? If so, i heard you can order them in pairs in various spring rates....would these springs work with any coilover systems? The reason i am asking is cause i have a set of Apexi N1 coilovers and i would like higher spring rates but it's really hard to get a hold of Apexi springs hence if i can get a set of eibach springs to work, i'll buythose. Thank You.
Old Aug 8, 2001 | 06:39 PM
civicrr's Avatar
Default Re: Flat top eibach springs....such a thing?? (eg-six)
Eibach race springs are flat on the top & bottom. You can check them out on http://www.ground-control.com. They will work if the 2 1/4" or 2 1/2" size is right. If you have 50 or 52 mm you will need to get H&R springs. Not sure who you can get those from.
JPerkMr954
Suspension & Brakes
Jan 18, 2011 01:10 PM
Mentat Ghola
Suspension & Brakes
Oct 13, 2005 01:00 PM
Understeer
Suspension & Brakes
Jun 15, 2005 09:14 AM
Neeko
May 2, 2002 06:08 AM
Petah
Aug 8, 2001 10:48 AM
