eibach springs
Old Aug 8, 2001 | 10:32 AM
Petah's Avatar
Default eibach springs
I was told that eibach made flat top springs for use with coilover applications....can anyone veryify this? If so, i heard you can order them in pairs in various spring rates....would these springs work with any coilover systems? The reason i am asking is cause i have a set of Apexi N1 coilovers and i would like higher spring rates but it's really hard to get a hold of Apexi springs hence if i can get a set of eibach springs to work, i'll buythose. Thank You.
Old Aug 8, 2001 | 10:45 AM
R1020's Avatar
Default Re: eibach springs (eg-six)
yes, eibach 'ERS' springs. you can get them in two different thicknesses, 3 different lengths, and a bunch of different rates. i know ground control sells them . . . http://www.ground-control.com. hth.
Old Aug 8, 2001 | 10:48 AM
Hooch'n's Avatar
Default Re: eibach springs (R1020)
Eibach springs!
I've heard that when you change spring you need to go with a camber kit, is that statment true?
JPerkMr954
Suspension & Brakes
Jan 18, 2011 01:10 PM
Understeer
Suspension & Brakes
Jun 15, 2005 09:14 AM
rambyCAMRY
Apr 6, 2004 10:51 PM
JDubya
Jun 25, 2003 12:31 PM
Petah
Aug 8, 2001 06:39 PM
