Selling all B Series parts....including 11 sec NA motor.
Shortblock is sold.
Head is sold.
The following parts are also on this engine and for sale...
RC 310cc injectors $200
STR fuel rail with Holley FPR $150
Hasport billet mount kit for B series into 88-91 crx $275
P28 with Skunk2 program $150
Type R shift linkage cut and welded for B series into 88-91 crx $100
ACT heavy duty clutch kit $150
Here is a list of all of the other B series stuff I have for sale...
AEM GSR alt. pulley (red) $25
96-up universal seat mount for drivers side (civic) $30
1 DOHC VTEC solenoid assembly $40
GSR stock cam gears $10 a set (many sets)
thermostat housing $20
LS head bolts (new) $50
90-93 LS drivers side mount (part that bolts to block) (new) $25
JDM CTR airbox and tube w/ K&N drop in $50
96 GSR ECU $120
GSR IAB canister $25
VTEC oil feed line with fitting for block and oil pressure sensor $45
GSR fuel rail $25
CRV crank pulley (good for supercharged motors) $40
B series alternator $50
HKS turbo timer $60
GSR radiator fan $25
JDM CTR strut tower brace (matches type r valve cover) $40
GSR valve cover (cut, paint has been stripped) $50
H23 shortblock with bad crank $150
2 vx wheels (paint has been stripped) $50
92-95 civic headlights $40
99 SI tranny (works fine but 2nd gear grinds at high rpm shifting) $400
MSD blaster 2 coil $20
SOHC ex MSD pro cap $25
CRX SI resistor box $20
Shipping is extra and if paypal is used, then 3% will be added
All parts are located in Rockingham, NC
Email me at butchbouldin@carolina.rr.com or butch.bouldin@verizonwireless.com if interested. Thanks
Pics of the motor can be found here. There are 4 pages of pics.
http://www.carolinahondas.com/...umb=1
Modified by Butch at 5:50 PM 8/5/2003
Modified by Butch at 6:29 PM 8/5/2003
Modified by Butch at 6:05 PM 8/6/2003
Modified by Butch at 9:33 PM 8/9/2003
Modified by Butch at 6:10 PM 8/10/2003
Head is sold.
96 GSR ECU $120
GSR fuel rail $25
HKS turbo timer $60
bump for a man that has a lot of quality parts for sale at great prices...how much shipped for that itr throttle body and r u interested in any trades???
I can do the R throttle body for $210 shipped, and the only trades I would consider would be K series parts.
On the OBD0 to OBD1 harness, sorry but I can't go that cheap.
up before bed. if anybody has any questions, the easiest way to reach me during the day is at butch.bouldin@verizonwireless.com. I won't be able to get back on here and check anything until tomorrow night.
thanks
thanks
All pm's and emails have been answered.
Header has 3" street collector with flange. It is the mild steel uncoated.
The only tranny I have for sale is a 99 SI tranny that grinds 2nd gear if you shift it at high rpms.
Thanks
Thanks
ill take the vtec selenoid assembly e mail me b16dragger@yahoo.com
asap i really need the valve press switch thanks pay pal is the same as the email
and im also verified thanks
