Removing gauge cluster from 95 Accord?
I"m trying to remove my gauge cluster from my dash. There are 2 screw on the top but I'm sure what else I have to remove, does evertying else just unsnap if I pull on it?
You will need to remove your center console because there are 2 hidden screws right under your climate control *****. You will also need to pry out your rear defogger switch (hidden screw behind), then pry out your moonroof/cruise control switch (another hidden screw), then take out your dash dim switch (yet another hidden screw. Remove the 2 climate control *****, and remove the 2 screws you have already found and BINGO! YOu know have acces to your guage cluster.
go here. i had to do it the hard way by finding all the screws.
http://web.tampabay.rr.com/aie...s.htm
allstarr7
Dec 18, 2007 02:49 PM
redsidriver
Feb 13, 2007 11:42 AM
saywhat
May 11, 2006 01:33 PM
