*********ep civic guy w/ a question for all you prelude guys.******
Old Aug 4, 2003 | 12:52 PM
DanielLaruso's Avatar
Default *********ep civic guy w/ a question for all you prelude guys.******
my girlfriend is looking at a 95 prelude w/ an h23 and 140,000 miles on it.
it seems to be in great shape, real clean w/ a thermal R&D cat back and an aem cai.
My question is what can be expected from a prelude w/ that many miles.
we haven't taken it out yet and the DEALER is asking 4300 for it.
Since i have no knowledge in the prelude field, i was hoping you guys could shed some light.
thanks in advance
Old Aug 4, 2003 | 02:00 PM
Elkins911's Avatar
Default Re: *********ep civic guy w/ a question for all you prelude guys.****** (DanielLaruso)
4300 seems like a decent price. the motor should run forever. i bought my 92 lude for 2500... it did have 200k+ miles on it with an excelent interior and body. i drove the single cam motor an extra 12k miles before i actually ripped a hole in the oil pan and blew the motor.
i now have an h22a..... loving every second of it. the swap is fairly inexpensive. i payed $3500 for the complete swap. if you know how to do swaps you can pick up the motor for around 2k. all and all, i would say get it... ALWAYS try to haggle the price.
Old Aug 4, 2003 | 02:06 PM
satan_srv's Avatar
Default Re: *********ep civic guy w/ a question for all you prelude guys.****** (Elkins911)
for an H23 with a big stroke and 140,000 miles on it I would have the bottom end inspected. I would be concerned about the main and rod bearings spinning eventually. Drop the pan and have a knowledgeable h22a/h23a builder inspect it.
Old Aug 4, 2003 | 02:09 PM
thanks, i realize it will run forever, my question now is the deal on w/ the h23, what are the specs, hp, torque, why is the 2.2 better than the 2.3???
just gimmee some feedback, thanks.
Old Aug 4, 2003 | 02:13 PM
Elkins911's Avatar
h22 is the vtec model of the h23... not to sure what the exact specs are, but i can point you to the right direction...
Old Aug 4, 2003 | 02:14 PM
Elkins911's Avatar
https://honda-tech.com/zerothread?id=549372
Old Aug 4, 2003 | 02:15 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanielLaruso &raquo;</TD></TR><TR><TD CLASS="quote">thanks, i realize it will run forever, my question now is the deal on w/ the h23, what are the specs, hp, torque, why is the 2.2 better than the 2.3???
just gimmee some feedback, thanks. </TD></TR></TABLE>
h23 is 160hp and 156 tq it has a bigger stroke so the power is earlier in the band and redline is 6500...it is a DOHC NON-Vtec head
The H22a is a DOHC VTEC motor like a B18C or B16A, just bigger. It makes 190hp at 6800rpms and 155 of torque at 5500 or so the redline is 7400.
The H22a is quite a bit faster and has VTEC, the H23 is defintely a great daily driver with the lower powerband and it's still a prelude
1/4 mile wise you're looking at 15.0 vs. 15.7 so the H23 still pulls decently.
Shakes's Avatar
space cadet
4th Generation
Year '92-'96
Model S Si Si VTEC
ENGINE
Type Aluminum-alloy in-line 4
Displacement 2156 cc 2259 cc 2157 cc
Horsepower@rpm (SAE net) 135@5200 160@5800 190@6800
Torque (lb.ft.) 142@4000 156@4500 158@5500
Compression Ratio 8.8:1 9.8:1 10.0:1
Valve Train SOHC, 16-Valve DOHC, 16-Valve DOHC, 16-Valve VTEC
Fuel Induction System PGM-FI
Ignition System Electronic
EPA Estimate (manual) 23/29 22/26 22/26
EPA Estimate (automatic) 23/28 22/27 N/A
DRIVE TRAIN
Type Front-Wheel Drive
Manual Transmission 5-Speed
Automatic Transmission 4-Speed N/A
Final Drive Ratio (MT/AT) 4.06/4.29 4.27/4.43 4.27/NA
BODY/SUSPENSION/CHASSIS
Body Type Unit Body
Suspension 4-Wheel Upper Wishbone, Lower Control Arm
Stabilizer Bar (mm, front/rear) 25.4/23.0
Steering Type Variable-Assist Power Rack-and-Pinion
Steering Wheel Turns, Lock-to-Lock 2.9
Turning Diameter, Curb-to-Curb (ft.) 35.9
Brakes 4-Wheel Power-Assisted Disc 4-Wheel Power-Assisted Disc w/ABS
Wheels 14-inch Steel Wheels w/Full Covers 15-inch Alloy Wheels
Tires 185/70 R14 87H 205/55 R15 87V
EXTERIOR DIMENSIONS
Wheelbase (in.) 100.4
Length (in.) 174.8
Width (in.) 69.5
Height (in.) 50.8
Track (in., front/rear) 60.0/59.6
Ground Clearance (in.) 5.7
Curb Weight (lbs., MT/AT) 2809/2862 2866/2921 2932/NA
Coefficient of Drag (Cd) .33
INTERIOR DIMENSIONS
Headroom (in., front/rear) 38.0/35.1
Legroom (in., front/rear) 44.2/28.1
Shoulder Room (in., front/rear) 54.0/50.6
Hiproom (in., front/rear) 52.2/41.4
Cargo Volume (cu. ft.) 7.9
Interior Volume (cu. ft.) 80.2
CAPACITIES
Engine Oil with Filter (qt.) ??
Fuel (gal.) 15.9
Cooling System (qts., MT/AT) ??
98tegLSvtec
Sep 21, 2007 11:02 AM
jaywoodz
Sep 16, 2006 05:25 AM
uneek4dr
Jan 22, 2006 03:01 PM
703_Sleeper
Nov 17, 2004 08:39 AM
JKDZ28
Jul 9, 2003 05:58 PM
