Toda D's Revisited.........
Old Aug 4, 2003 | 12:39 PM
Drag R's Avatar
Default Toda D's Revisited.........
Toda Spec D vs Skunk2 Stage 2
Modified by Drag R at 3:00 PM 8/5/2003
Old Aug 4, 2003 | 01:01 PM
WAFFLES's Avatar
Default Re: Toda D's Revisited......... (Drag R)
Power all the way to 10.5!!!! Damn!
Old Aug 4, 2003 | 01:10 PM
J2turbo21's Avatar
Default Re: Toda D's Revisited......... (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">Power all the way to 10.5!!!! Damn!</TD></TR></TABLE>
hehe thats mph not rpm's
Old Aug 4, 2003 | 01:32 PM
xJ.SLOTHx's Avatar
so, skunk2 stage2's vs toda D's and the skunks came out on top with that particular motor setup. im pretty impressed.
Old Aug 4, 2003 | 01:51 PM
C_A_T's Avatar
Default Re: Toda D's Revisited......... (ian)
Just for reference, on 2.0+ liter, 14:1 (or higher) compression race motors simply swapping the Skunk 3's out for Spec D's was worth 12-15 hp. All depends on the setup.
C_A_T
Old Aug 4, 2003 | 01:59 PM
Suprdave's Avatar
Default Re: Toda D's Revisited......... (C_A_T)
Wasn't that on Javier's motor?
Every motor responds differently...
Suprdave
Old Aug 4, 2003 | 02:00 PM
CHEETAH's Avatar
thats a good effort comparing the cams that I'm sure many will appreciate ... I still bet on the Toda cams though, on the cars I tune I notice different results when comparing Toda vs Skunk2 ... nothing biased here either cause even Endyn is really impressed with Skunk2 cams, so I gave the Skunk2 and Jun fair shots but I'm really impressed with Toda D cams and the Killer cams ... unfortunately I guess I'm the only one that sees good results with Toda cams maybe its the combinations of headers and head porters that I use ? I dunno.
Well, either way this is a good informative trend
Greg
Old Aug 4, 2003 | 02:03 PM
C_A_T's Avatar
Default Re: Toda D's Revisited......... (Suprdave)
Bingo, all depends on the setup. Got to have an _integrated_ engine building approach - too many people mix and match whatever looks best this week. I've seen some street cars make really awesome power on Skunk 3's, and some others do not so well with basically the same setup. Makes me glad I don't have to decide on parts (or build the motor), only tune up the combo that the customer brings me
C_A_T
Old Aug 4, 2003 | 03:21 PM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_A_T &raquo;</TD></TR><TR><TD CLASS="quote"> I've seen some street cars make really awesome power on Skunk 3's, and some others do not so well with basically the same setup. Makes me glad I don't have to decide on parts (or build the motor), only tune up the combo that the customer brings me
C_A_T</TD></TR></TABLE>
this is one of the most real comments i've seen in a while ... very true on this, but try explaining that to some people who don't understand some of the dynamics of these motor setups.
Greg
Old Aug 4, 2003 | 08:19 PM
genius's Avatar
i believe that with more compression the toda D would outperform the skunks2's
the overlap of the D's just killed the compression
the motor was built for the street and milder cams suit it better.
with more compression i wouldnt have to close off some of the overlap(ex. cam was advanced like 8 deg.), graph would be higher and it would peak at higher rpm ...so it could of made 15hp differance.
each cam has to be matched to the right set up and D's are top dog for all out monster comp. motors...no doubt
Old Aug 5, 2003 | 12:44 AM
F1Spec's Avatar
i wonder what parts (besides the cams) were used to get 260hp/176tq. must be 2.0l. anybody knows the info on this "$15,000" motor? thanks.
Old Aug 5, 2003 | 01:34 AM
fox297's Avatar
Can you convert MPH into RPM. I'm sure people would like to know the rpm at peak hp.
Old Aug 5, 2003 | 01:35 AM
StinkyTofu's Avatar
Default Re: Toda D's Revisited......... (fox297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">Can you convert MPH into RPM. I'm sure people would like to know the rpm at peak hp.</TD></TR></TABLE>
Depends on the tranny and what size wheel/tire combo hes running.
Old Aug 5, 2003 | 04:36 AM
b19coupe's Avatar
No matter how you slice it, those are very nice numbers for all motor. I have not given up on the 'D's yet; building a higher compression motor to try and get these cams to work. On my engine, the 'D's kill down low, at about 3,000 rpm the tires just break loose and spin-street tires , very mild take-off, then full throttle at about 2,000 rpm. It is up top, when those huge VTEC lobes engage, that my motor does not really perform all that well. Work still to be done. Just love these kind of posts, good info
Cheers to Jeff and Greg for taking the time and putting forth the effort to give us this info
Old Aug 5, 2003 | 05:51 AM
MackSpeed-616's Avatar
Default Re: Toda D's Revisited......... (b19coupe)
aww isnt that graph cute
Old Aug 5, 2003 | 06:51 AM
Drag R's Avatar
Default Re: Toda D's Revisited......... (MackSpeed-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">aww isnt that graph cute </TD></TR></TABLE>
the graph is cute. Its about time someone did those cams some justice, however I still think that is more that can be achieved from them, maybe more compression.. the overlap is rediculous on D's....13.5 is alot, maybe 14:1 next
nick
Old Aug 5, 2003 | 06:53 AM
WAFFLES's Avatar
Default Re: Toda D's Revisited......... (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">
hehe thats mph not rpm's </TD></TR></TABLE>
I'm soooo stinking retarded!
Old Aug 5, 2003 | 07:37 AM
xJ.SLOTHx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R &raquo;</TD></TR><TR><TD CLASS="quote">
nick</TD></TR></TABLE>
i'd be interested in seeing some graphs and what not of motors in the 14:1 range
b19coupe
56
Apr 22, 2013 10:24 AM
b19coupe
49
Dec 8, 2006 10:01 AM
Allmota O
10
Feb 10, 2006 07:25 PM
yellowmonkeyboy
Aug 13, 2003 09:07 AM
TakumiFujiwara
16
May 10, 2003 06:58 PM
