22mm swaybar with OEM GSR endlinks
Old Aug 4, 2003 | 10:17 AM
Jonmon's Avatar
Default 22mm swaybar with OEM GSR endlinks
I purchased my car with an older Comptech 22mm swaybar with comptech endlinks installed on it. Comptech endlinks wore out, so I tried to put some OEM GSR endlinks back on.
What am I missing to make this match up correctly ???
Also, the hole in the swaybar is bigger than the hole in the endlink.
Any suggestions ?
What OEM pieces am I missing ?
Old Aug 4, 2003 | 11:35 AM
ingrate's Avatar
25 Year Member
Default Re: 22mm swaybar with OEM GSR endlinks (Jonmon)
My memory might be a little hazy, but aren't there supposed to be little bushings and collars in the holes on the swaybar?
Old Aug 4, 2003 | 11:57 AM
-BlueGSR-'s Avatar
Default Re: 22mm swaybar with OEM GSR endlinks (ingrate)
^^ yup.
You're missing the endlink bushing, the endlink collar, and the endlink bolt.
Old Aug 4, 2003 | 02:00 PM
Tweakmeister's Avatar
Default Re: 22mm swaybar with OEM GSR endlinks (-BlueGSR-)
give comptech a call directly.
they may even send you some for free.
Old Aug 4, 2003 | 02:02 PM
lustedp's Avatar
jon the swaybar itself has a bushing where it connects to the endlink.
it's not an endlink bushing, trust me i ordered this part for him, it's the swaybar bushing itself and the bolt that goes through it
Old Aug 4, 2003 | 03:08 PM
Jonmon's Avatar
Default Re: (lustedp)
This is Comptech's reply when I contacted them about the worn endlink :
Jon,
We can sell you replacements, they are $21.00 each. We are currently looking into using a different end link as we've had complaints of them wearing out too soon. You can check back at a later time for new updates on it if you'd like. If you wanted to hold off until the new ones were available, you can remove the swaybar and leave the tie bar on. Let me know. Thanks.
-Joe.
Old Aug 4, 2003 | 03:09 PM
Jonmon's Avatar
Default Re: (Jonmon)
forget this madness, i'm just going to buy an ITR OEM 22mm swaybar, and get the OEM pieces that I need
freakin' comptech..... curses.....
looks like i've got a Comptech 22mm swaybar for sale if anyone wants it
i'll let it go for pretty cheap
Old Aug 4, 2003 | 06:25 PM
lustedp's Avatar
comptech will sell easily on ebay
ner0x
Oct 1, 2010 08:19 AM
99blusi
Sep 10, 2004 12:48 PM
MugenFan
Nov 20, 2003 11:51 PM
jdmjunky
Feb 24, 2003 03:40 PM
