rear disk swap.....what MC
Old Aug 4, 2003 | 07:38 AM
VTgringo's Avatar
Default rear disk swap.....what MC
i just swapped i a set of rear trailing arms from a 93 integ and i was wondering if i should use a different MC. should i just grab the MC off the 93 teg? will that work? do i need any new gaskets when i do that. thanks for the help
Old Aug 4, 2003 | 08:26 AM
Caleb V's Avatar
Default Re: rear disk swap.....what MC (VTgringo)
Grab the Master Cylinder, brake booster and don't forget the proportioning valve to get the correct amount of fluid going to the rear disks.
Old Aug 4, 2003 | 04:09 PM
d357r0y's Avatar
Or get an EX MC 15/16ths.. but still get the por.valve.
Old Aug 4, 2003 | 04:12 PM
CRXvato's Avatar
What these guys said.
Old Aug 4, 2003 | 05:50 PM
VTgringo's Avatar
Default Re: rear disk swap.....what MC (CRXvato)
ok, it should still be sitting up at the junk yard. any gaskets that need to be replaced when i get that integra master cylinder in?
Old Aug 4, 2003 | 06:02 PM
FourthGenHatch's Avatar
Let me be the first to tell you don't use Junkyard MCs!!! If I were you buy the Junkyard MC and Booster then go to an auto parts store and get Remanufactured MC (and booster if you want but those tend to hold up better) and use the JY parts for the core refund. My JY MC costs me $10. My Reman MC was $70 with $30 core. So I got basically $20 profit from my JY MC. With Remans you know they are clean and work, you don't with JY parts.
Old Aug 4, 2003 | 06:35 PM
Timmah!!'s Avatar
Default Re: rear disk swap.....what MC (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Let me be the first to tell you don't use Junkyard MCs!!! If I were you buy the Junkyard MC and Booster then go to an auto parts store and get Remanufactured MC (and booster if you want but those tend to hold up better) and use the JY parts for the core refund. My JY MC costs me $10. My Reman MC was $70 with $30 core. So I got basically $20 profit from my JY MC. With Remans you know they are clean and work, you don't with JY parts.</TD></TR></TABLE>
Im with him on this. And yes get the valve.
hammergunner
Mar 11, 2009 06:04 PM
llantaguy
Jul 13, 2007 12:29 AM
whole9
10
Mar 30, 2007 10:00 PM
blackccoupe
Sep 14, 2003 07:23 PM
jdmcivicferio
Apr 2, 2003 03:49 PM
