Here is a little somtin somtin for you H22 boys
Old Aug 4, 2003 | 06:53 AM
Blitzkrieg's Avatar
Default Here is a little somtin somtin for you H22 boys
We are cooking this little treat up for a 97 Prelude/Automatic. The name of the game here is antireversion quick spoolup collector. This setup will spool your turbo 500 rpms sooner. Wait until you see the intercooler. No huge volume FMIC here. I will keep you all posted on the progress of this project. FYI the tranny is all
Level-10
Old Aug 4, 2003 | 07:40 AM
prelude beast's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (Blitzkrieg)
What size turbo is that.
Old Aug 4, 2003 | 07:42 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">FYI the tranny is all Level-10</TD></TR></TABLE>
I have yet to hear of a good experience with Level 10 work on the Prelude Sportshift tranny. Hope it holds up for you. How much boost are you planning on running on it (I'm assuming your engine has stock internals)?
Old Aug 4, 2003 | 07:51 AM
Blitzkrieg's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (sharkcohen)
That is a T3/T4E custom trim from Innovative turbo. The motor has 83 miles on it after a full rebuild (JE pistons, Crower rods, Darton sleeves, Ferreia valves, Ect.). I have had Level-10 products before with no issues, but I will kep you all informed, Also on the race program we are planning on 1.5Bar.
Old Aug 4, 2003 | 08:30 AM
ffgeon's Avatar
are they just going to cut some triangles and fill the gap?
Old Aug 4, 2003 | 08:32 AM
Blitzkrieg's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (ffgeon)
There is allot more to it than that, but close Most of this is just tacked together to test fit.
Old Aug 4, 2003 | 10:02 AM
Prod's Avatar
Posting here now too eh ? (audiworld)
what are you running for engine management on this car ?
Old Aug 4, 2003 | 10:07 AM
Blitzkrieg's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (Prod)
Come on I am a forum ***** you know that. I am everywhere We are using our onw brand piggyback ECU. We have control over fueling as well as ignition. We also added a seperate 3 BAR MAP sensor for reference. Our ECU also clamps the stock MAP sensor so there is no need for faulty check valves
Old Aug 4, 2003 | 11:00 AM
sharkcohen's Avatar
Sounds much like the EFI PMS.
Old Sep 15, 2003 | 05:45 AM
Blitzkrieg's Avatar
Here is an update
Old Sep 15, 2003 | 06:47 AM
BoM's Avatar
BoM
by any chance are you the black lude with turbo emblem on the back? i've seen your car at atco before. do you mind me asking, what times you ran back then? and now? my bro has an ss lude i wanted to boost it, but not sure if it'll handle it.
hows the tranny holding?
Old Sep 15, 2003 | 07:38 AM
Blitzkrieg's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (BoM)
The best time back then on the POS F-Max kit was 13.8 @ 103 on 13psi and race gas. We haven't ran the car with this setup as of yet. The tranny is being built by Level 10.
Old Sep 15, 2003 | 08:14 AM
GraphiteAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ffgeon &raquo;</TD></TR><TR><TD CLASS="quote">are they just going to cut some triangles and fill the gap?</TD></TR></TABLE>
You called that one. Look at the pics, you could fry an egg on it nicely
Old Sep 15, 2003 | 08:43 AM
SiRkid's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (GraphiteAccord)
what makes you think your mani will help rpm spool up by 500 rpm?
stuff looks good though
Old Sep 16, 2003 | 05:41 AM
Blitzkrieg's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (SiRkid)
There are some tricks inside the collector area that transforms it into a checkvalve. Therefore there is no reversion of the exhaust into the non firing runners and ports. This forces the gasses into the turbine for a quicker spool over logs and equal length setups.
Old Sep 16, 2003 | 05:52 AM
tony1's Avatar
Care to explain how this works, cause i don't see it happening...
Old Sep 16, 2003 | 06:05 AM
boosted hybrid's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (tony1)
Exactly what i was thinking.
Old Sep 16, 2003 | 06:34 AM
DaveF's Avatar
did this turbo prelude ever go to the philly street races???
Old Sep 16, 2003 | 06:52 AM
BrokenVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Care to explain how this works, cause i don't see it happening...</TD></TR></TABLE>
Old Sep 16, 2003 | 09:55 AM
Full-Race Geoff's Avatar
where is the "check valve" ??
Old Sep 16, 2003 | 10:09 AM
Signal Auto's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (FFgeoff)
Mebbe there are 4 check valves
Old Sep 16, 2003 | 10:27 AM
egg's Avatar
egg
i would think that collector would cause a lot of turbulence. the exhaust gases are flowing into a large volume area before entering the turbo. as what ffgeoff asked, where are the check valves? i dont see any welds coming from the inside of the collector, either that or the welds are completely cold.
Old Sep 16, 2003 | 10:36 AM
Blitzkrieg's Avatar
Default Re: Here is a little somtin somtin for you H22 boys (egg)
The bulkhead it's self acts as an antireversion chamber or also known as a pulse trap collector. With the "wall" around the primarys the exhaust gasses create a pressure boundry that restricts it from entering back into the primary tubes of non firing cylinders. This setup has been used in a Porsche Bonneville record setting car. This same 930 was running 9sec 1/4mi before Eddie Bello was a glimmer in his momma's eye. We have also ran this setup on our record setting Audi S4. The Torque is amazing and response is unlike any other collector design.
Old Sep 16, 2003 | 10:53 AM
Overblown-Teg's Avatar
hmm.. so if you put a pressure gauge on each runner the non firing runners will have zero pressure while the collector will have pressure? I'm not buying it.
Old Sep 16, 2003 | 10:55 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Could you even classify that as a collector? More like a tunnel of turbulence.
