Alignment after lowering with TEIN S-Tech springs?
Old Aug 8, 2001 | 07:08 AM
Edwin's Avatar
Default Alignment after lowering with TEIN S-Tech springs?
Is an alignment necessary after lowering with TEIN S-Tech springs?
Old Aug 8, 2001 | 07:52 AM
S13Koop's Avatar
Default Re: Alignment after lowering with TEIN S-Tech springs? (Edwin)
Don't necessarily know if its needed but after my install I didn't get one. Of course 6 months later I've switched to their coilovers I can't commnent on the long term effects. But during the time I had them, I didn't notice any problems other than the inside of my tires wearing away!!
Old Aug 8, 2001 | 08:28 AM
R1020's Avatar
it's always a good idea to get an alignment after removing/re-installing any suspension pieces. after installing my konis and GCs, my toe was out a lot in the rear.
[Modified by R1020, 12:28 PM 8/8/2001]
Old Aug 8, 2001 | 08:31 AM
norice's Avatar
You should always get an alignment after futzing with the suspension. Mine was *way* out of spec after I installed a new set of shocks and springs. I had it aligned to factory specs about a month before so I know that the swap caused the misalignment. There is nothing that you can do about camber, but your toe could be way off.
Old Jun 26, 2004 | 02:51 PM
AlekSir's Avatar
Default Re: Alignment after lowering with TEIN S-Tech springs? (norice)
YES, you better get one
Old Jun 26, 2004 | 05:01 PM
Edwin's Avatar
Holy ***** this thread was resurrected from the dead!
My car has been aligned a few times since. Plus I'm sporting Zeal B2 coilovers currently.
Old Jun 26, 2004 | 10:04 PM
trutuner's Avatar
Default Re: (Edwin)
well i've had tem for over a year, and still no alinement!, I love them so much!...-Roger
Old Jul 1, 2011 | 10:48 AM
RGoose18's Avatar
Back from the dead, I'm installing some H&R sports today (they'll only be on for a few months) anyone think I can cheap out and NOT get an alignment??? Competent shops are super difficult to come by in my area and it's a total PITA to track one down
Old Jul 1, 2011 | 11:35 AM
Tekkaboy's Avatar
You can always do your own alignment: https://honda-tech.com/forums/acura-integra-type-r-8/diy-r-alignment-quick-method-2631081/
Old Jul 1, 2011 | 11:40 AM
R134's Avatar
When I did my koni/gc with a small drop I went for an alignment and everything was still in spec.
Old Jul 1, 2011 | 12:21 PM
Todd00's Avatar
I said I don't want a title!
The R is double-wishbone, so just lowering the car won't throw it off that much--unlike a strut car that can be severely out when you even breathe on the springs.
But still, if it were my daily I'd get a alignment anyways. if a weekend car, probably don't bother.
Or, go to one of the places that offer lifetime alignments. It is only like $50 more and it'll pay for itself in the long run. Just make sure they can handle lowered cars, though.
Old Jul 1, 2011 | 01:10 PM
b18c5 power's Avatar
Well you should ! Tires are not cheap to replace , if out of spec fast tire wear will occur !Camber kits are not necessary,but imho they are great to align camber back to spec !
Old Jul 1, 2011 | 03:58 PM
RGoose18's Avatar
diggin into this project right now one thing I can't seem to find is how much I should torque the OEM top hats after installing the H&R's (when the assembly is off the car)
I know its kind of a noobish question, but I've never attacked a suspension install before
kartman5
Honda Civic (2006 - 2015)
10
Jan 29, 2009 10:15 PM
Mr.VoRt3X
Jun 10, 2007 02:43 PM
and1b0i
Nov 1, 2005 08:55 AM
barely4dr
Suspension & Brakes
Aug 8, 2005 01:54 PM
EF-9SiR
12
Apr 13, 2003 06:39 PM
