Civic radiator in Integra...again.
Old Aug 3, 2003 | 11:56 PM
NyQuiL's Avatar
Default Civic radiator in Integra...again.
Ive searched this, but the threads i found didnt really offer much.
Has anyone done this with an aftermarket civic radiator such as pwr or C&R?
and got it to work in a 94+ integra.
Im hoping to do it with mine since i want more room for my maniold/wastegate. Im not to sure on what supports are the bottom and what needs to be refabricated.
I also dont have ac if that helps.
Old Aug 3, 2003 | 11:58 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: Civic radiator in Integra...again. (NyQuiL)
Edit: I misread
ignore this idiot
Modified by B18C_DC2 at 1:17 AM 8/4/2003
Old Aug 4, 2003 | 12:12 AM
NyQuiL's Avatar
im sorry, but that reply made no sense to me.
Old Aug 4, 2003 | 12:25 AM
turbospool's Avatar
Default Re: (NyQuiL)
you drill out your left bottome radiator mount and reweld or rivent it under the civic radiator. i think this is the only way, anyboyd care to share?
Old Aug 4, 2003 | 02:33 PM
mskibbz-T's Avatar
Default Re: (turbospool)
Search in the forced induction forum... It is just a matter of rewelding the bottom mounts in the new location. Hoses should be the same for the civic radiator, although you may need to clamp them more.
Old Aug 4, 2003 | 04:49 PM
ILOVEGIRLS's Avatar
im using a civic fluidyne. one of the leg on the bottom lines up just fine, other one doesnt so im running peglegged. and the top mount had to be modified, other than that no problems so far.. btw, use a slim fan, the stock fan is pretty darn close to the slave cylinder.
Old Aug 4, 2003 | 07:04 PM
turbospool's Avatar
Default Re: Civic radiator in Integra...again. (ILOVEGIRLS)
what did you do to the top mount?
Old Aug 4, 2003 | 07:57 PM
96 Ls lnTeG's Avatar
Default Re: Civic radiator in Integra...again. (turbospool)
http://tech.hybridgarage.com/tech/jsrad/jsrad.html
Here This MIte Help Good Luck
Old Aug 4, 2003 | 08:25 PM
ILOVEGIRLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbospool &raquo;</TD></TR><TR><TD CLASS="quote">what did you do to the top mount?</TD></TR></TABLE>
i flipped it upside down. worked like a charm. ill see if i could get some pics for yah
Old Aug 4, 2003 | 09:17 PM
NyQuiL's Avatar
pics pics pics!!
Old Dec 18, 2003 | 06:40 AM
RedTegLS's Avatar
I would like to see pics also!
Old Dec 18, 2003 | 10:19 AM
DA-MAX's Avatar
Default Re: (RedTegLS)
are any of you who are doing this having any cooling issues?? I assume since its a dual core radiator though, its fine right??
Old Dec 18, 2003 | 10:29 AM
Mr. Softee's Avatar
Default Re: (DA-MAX)
i have a single core civic one, it is peg leggin and zip tied on the top. no cooling issues, its cherry.
shermanyang
Honda CR-V & Element
Sep 7, 2012 10:34 AM
teddy_dc2
Oct 4, 2006 03:12 PM
JDM turbo DC
Mar 1, 2006 12:41 PM
i3oricua
Apr 9, 2005 07:43 PM
Peter K
Feb 24, 2003 06:36 AM
