D16Z6 engine beutification
Old Aug 3, 2003 | 10:32 PM
94SiHatch's Avatar
Default D16Z6 engine beautification
basically, i guess i just needed something to work on so I made some of my old oily, dirty underhood parts look better then new...
I was swapping my old cracked exhuast manifold to a brand new one, and got stuck...so I started a different project. I painted the valve cover Flat black, and sanded down the lettering with fine grit paper, painted the bolt heads and oil cap aluminum, and also painted the exhuast manifold heat shield aluminum(not shown).
Cant finish the manifold install until i get a new o2 sensor in the morning...but heres some pictures of the valve cover, bolts and oil cap...along with the new manifold hanging on the studs.
Cant decide if I want to use the heat shield or not, I think it looks kind of nice. I also plan on using the remnants of a hose techniques kit from my other car to further clean up. I dont want to get really carried away, this motor is only temporary.
Old Aug 3, 2003 | 10:33 PM
jazz215's Avatar
nice
Old Aug 3, 2003 | 10:34 PM
94SiHatch's Avatar
Default Re: (jazz215)
sorry, hit post too quickly.
Old Aug 3, 2003 | 10:36 PM
Daniel's Avatar
Default Re: D16Z6 engine beautification (94SiHatch)
Seriously, that looks BAD ***. Beautiful engine bay!
Old Aug 3, 2003 | 10:40 PM
AlphaQup's Avatar
Default Re: (94SiHatch)
start your own Maaco haha j/k bro. how much would you sell that motor for? I might be interested when you do your swap.
Old Aug 3, 2003 | 10:41 PM
94SiHatch's Avatar
Default Re: D16Z6 engine beautification (Daniel)
I forgot to mention...anyone that thinks that D16 VTEC makes no difference...drive one with malfuntioning Vtec...yeah it really blows.
After the rpm where the crossover should be the engine just will not rev through the higher rpm range. This is especially noticable in 3rd gear and up. The cracked manifold and old o2 were throwing an engine code and disabling all my fun. At least I hope thats all that was causing it...i will know for sure tommorrow.
Old Aug 3, 2003 | 10:45 PM
99EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">Seriously, that looks BAD ***. Beautiful engine bay! </TD></TR></TABLE>
its so so nice
Old Aug 3, 2003 | 10:46 PM
94SiHatch's Avatar
I dont even know what they are worth...I know a long block d16 goes for 750 from HMO. I didnt pay that, I got raped ...but everything under the hood was replaced too, hoses belts and such so I cant complain.
Make an offer I guess. I got it with 70k miles....dont plan on putting too much on it. Dont know how long unti I actually have the money for the swap though. Ill most definitely be posting when I order the motor, so keep an eye out. Im definitely interested in selling what Im not using.
Old Aug 3, 2003 | 10:48 PM
EARLdaSQUIRREL's Avatar
official honda whore
you prob had vtec, atleast on my old si it was a tird even up high, lol thank goodness for b18c swaps
Old Aug 3, 2003 | 10:50 PM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">I dont even know what they are worth...I know a long block d16 goes for 750 from HMO. I didnt pay that, I got raped ...but everything under the hood was replaced too, hoses belts and such so I cant complain.
Make an offer I guess. I got it with 70k miles....dont plan on putting too much on it. Dont know how long unti I actually have the money for the swap though. Ill most definitely be posting when I order the motor, so keep an eye out. Im definitely interested in selling what Im not using.</TD></TR></TABLE>
fO shiZZle Mah NizZle ... I'll be on the lookout The motor aint for me so it can wait. I was just curious how much you would give it up for.
Old Aug 3, 2003 | 11:04 PM
RyanEJ8's Avatar
Looks good!
Old Aug 3, 2003 | 11:10 PM
Mr. Thunderlips's Avatar
You gotta pull that bitch out to get her really clean...
Old Aug 3, 2003 | 11:14 PM
EL-Driver's Avatar
Man that looks really sweet...
Just curious, what color is the Header painted?
Old Aug 3, 2003 | 11:16 PM
Ya@inlinePRO's Avatar
why do you want to get rid of that motor, is something wrong with it? boost it. its a fun motor.
Old Aug 3, 2003 | 11:18 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: (kwik2nec)
get some tire shine grease or foam and spray it all over the black rubber hoses to make it show up more ...
Old Aug 3, 2003 | 11:34 PM
94SiHatch's Avatar
Default Re: (B18C_DC2)
Im not done cleaning yet, i just did the painting tonight. Ill get more into it next weekend.
The manifold is brand new, I havent painted it...thats just the way it came. cast iron I would imagine.
And as for Vtec...it most definitely was not working. It stopped the other day when the temporary weld on the old manifold let go, and toasted the o2 sensor. Ive drivn the car with and without it, and there is a noticable top end difference. It will pull strong to the top of 3rd and beginning of 4th with vtec. now it just pulls timing and dumps fuel at the mid point of 3rd gear(or so it feels)...really sucks.
Old Aug 3, 2003 | 11:36 PM
94SiHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik2nec &raquo;</TD></TR><TR><TD CLASS="quote">why do you want to get rid of that motor, is something wrong with it? boost it. its a fun motor.</TD></TR></TABLE>
because its kind of in the way of the h22 destined to go between the strut towers.
Old Aug 3, 2003 | 11:47 PM
MPower332TI's Avatar
H22 D16 . Oh and also on the lettering on your valve cover its alot easier to rub a little vasoline on them before you paint and then wipe the vasoline off. Bam then you got some nice shinny letter with minimal work.
Old Aug 3, 2003 | 11:48 PM
EG2 SiR's Avatar
immaculate! That is super badd-o
Old Aug 4, 2003 | 12:00 AM
94SiHatch's Avatar
Default Re: (EG2 SiR)
the letters were nasty dirty too, so they needed some work anyways.
Old Aug 4, 2003 | 12:19 AM
krazyDOHC's Avatar
Default Re: (jDmDxTuRd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd &raquo;</TD></TR><TR><TD CLASS="quote">H22 D16 . Oh and also on the lettering on your valve cover its alot easier to rub a little vasoline on them before you paint and then wipe the vasoline off. Bam then you got some nice shinny letter with minimal work. </TD></TR></TABLE>
and to you for underestimating a d16
btw ...engine bay looks good....wished i had ABS
Old Aug 4, 2003 | 12:24 AM
94SiHatch's Avatar
Default Re: (krazySOHC)
1. Dont turn this into a motor vs. motor war...thats stupid...everyone has preferences.
2. Im fully aware of how far a d16 can go...it just isnt my thing. My last car made over 200 ft/lbs to the wheels (albeit 600lbs heavier)...and im just not into the power band of the smaller motors. The h22 was chosen due to the fact it makes plenty of torque and is cheaper then a B18C5. That and something about absolutely filling the engine bay just turns me on.
Old Aug 4, 2003 | 12:26 AM
94SiHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC &raquo;</TD></TR><TR><TD CLASS="quote">btw ...engine bay looks good....wished i had ABS </TD></TR></TABLE>
And my ABS is on the fritz...hasnt worked since I bought it and i havent gotten around to diagnosing it yet. its on the list of things to do though. could super low brake pads or improperly bled lines be to blame? i laready have new pads, just havent gotten around to installing yet. Already checked all the fuses and relays...so i know they are ok.
Old Aug 4, 2003 | 05:43 AM
blazinb16's Avatar
And my ABS is on the fritz...hasnt worked since I bought it and i havent gotten around to diagnosing it yet. its on the list of things to do though. could super low brake pads or improperly bled lines be to blame? i laready have new pads, just havent gotten around to installing yet. Already checked all the fuses and relays...so i know they are ok.</TD></TR></TABLE>
your si came with abs?..i wasent aware that that was even an option..when i had my 95 si it 4weel disk but no abs....but ya i'm lovin the clean engine bay..just how i like it
Old Aug 4, 2003 | 05:51 AM
nate_d's Avatar
holy crap, nice work bro!
