h22a in integra 90-93
Old Aug 3, 2003 | 08:42 PM
88civicHB703's Avatar
Default h22a in integra 90-93
me and my friend was having a discussion on h22a swap into our DA9 or integra 90-93... we think it would with just different mount point is it true or h22 have the same mount point as the b-series?
Old Aug 3, 2003 | 09:07 PM
psychotic_z's Avatar
Default Re: h22a in integra 90-93 (88civicHB703)
Different mount points are definately used...
http://www.g2ic.com/forums/sho...ber=1
Take a look at this post.. this guy put an H22 in his DA9 but... damn, he did a lot of work to make it fit. Mounts need to be custom made and welded/relocated in our chassis, then you need to notch the rear cross member, need to install the lude's VSS and gauge cluster (speed signals aren't compatable), and things like that. I'd imagine the thing would fly like no other if you can make it work
ExplicitSpeed360
Feb 5, 2007 04:59 PM
B18 CYA
Oct 24, 2006 12:14 PM
stevey323
Oct 1, 2006 12:24 PM
EkPudge
Jul 10, 2006 09:05 PM
blueskiesfade609
Feb 5, 2004 01:11 PM
