PROJECT b20/vtec motor done, in car, running...but....
Old Aug 3, 2003 | 08:05 PM
slowazzhatch's Avatar
Default PROJECT b20/vtec motor done, in car, running...but....
well the car is strong as hell below about 5500 rpm's a huge torque monster i can feel a big *** difference, but when ever it goes into vtec it feels like it hits a pocket of air and feels like it fall son it face, like it takes alot longer to get from 56-7800 than from 1500-5500, i dont get it, we thought it was the fuel pump so we put in a new fuel pump, still did it, maybe caouse it be cause i am running a stock LS fuel pressure reg?, i have an adjustable but i lost the part for it...help me out here guys, if i can fix this, it will be strong as hell, deffinetly a mid-high 13 second car
thanks
i will post pics of the motor 2mar0 in the car
matt
Old Aug 3, 2003 | 08:30 PM
xJ.SLOTHx's Avatar
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (slowazzhatch)
sounds like a lack of fuel in higher rpms ... id check that first. also check ur dist. & plugs while ur at it.
Old Aug 3, 2003 | 08:52 PM
powerofdreams8's Avatar
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (ian)
fuel pressure is at 30 psi at idle right now- can anyone estimate what it should be?
Old Aug 3, 2003 | 08:55 PM
importimage's Avatar
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (powerofdreams8)
30 seems low. I am a B20 VTEC turbo set up and at idle it is 48 psi.
Old Aug 3, 2003 | 09:38 PM
function83's Avatar
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (importimage)
yes increase the fuel pressure, b20vtec motors are fuel monsters.
Old Aug 3, 2003 | 10:23 PM
G U E C O's Avatar
tell me if it pulls harder
Old Aug 4, 2003 | 05:24 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (stock93cx)
Crank up the fuel pressure. Mines 40 @ idle w/ my B20. Still needs to be about 43psi for me, take a few runs and see what you come up with,
Blaze
Old Aug 4, 2003 | 05:33 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerofdreams8 &raquo;</TD></TR><TR><TD CLASS="quote">fuel pressure is at 30 psi at idle right now- can anyone estimate what it should be?</TD></TR></TABLE>
increase immediately
Old Aug 4, 2003 | 08:44 PM
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (rodrez)
fuel pressure at 42 now... MAJOR difference. Top end and idle smoothed out- it is like a different car.
Old Aug 4, 2003 | 09:22 PM
G U E C O's Avatar
does it pull?
Old Aug 4, 2003 | 09:51 PM
tangb2023
Guest
Posts: n/a
i have a b20b.. not smooth at high end.. i have no fuel regulator. i know stock is 30. psi on eg's. is it worth getting one.. ? does it pull much harder.. plus what is the gas milage? is sucks alot of gas already.. plus what is a good fpr??
Old Aug 5, 2003 | 04:19 PM
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (tangb2023)
yes i would say get a FPR
well i've got it set to about 40 at idle, i've got a subaru wrx stock fuel pump in there, i think either 195 or 205 a major difference from my stock DX one, 90 to 205...then i have my stock b16a injectors....god damn i love the torque in that car, top end pulls hard as hell, its like nothing i've felt all motor
"it feels like a roller coaster" -powerofdreams8 g/f
Old Aug 5, 2003 | 04:35 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowazzhatch &raquo;</TD></TR><TR><TD CLASS="quote">yes i would say get a FPR
Good deal, glad the fuel pressure trick worked
Old Sep 10, 2003 | 02:43 PM
i think i need some new injectors...yes or no
Old Sep 10, 2003 | 03:34 PM
porsche997dc2's Avatar
If you have extra cash, get a 310cc injectors.
Old Sep 10, 2003 | 04:39 PM
mishima_beef's Avatar
what do u rev the motor to?
i hear high revs kill ls/vtecs and b20/vtecs
Old Sep 10, 2003 | 05:13 PM
rodrez.'s Avatar
Default Re: (mishima_beef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mishima_beef &raquo;</TD></TR><TR><TD CLASS="quote">what do u rev the motor to?
i hear high revs kill ls/vtecs and b20/vtecs</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=501372
Old Sep 10, 2003 | 06:11 PM
GZR4DR's Avatar
Default Re: (rodrez)
Factory B series vtec motors idle at 40-42psi. 30psi was definately to low, hence why the car fell flat on its face at high RPM's.
Also running such low fuel pressure can hurt the engine because it is running was to lean. Good to see you fixed it.
Old Sep 10, 2003 | 09:34 PM
blackANESE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowazzhatch &raquo;</TD></TR><TR><TD CLASS="quote">i think i need some new injectors...yes or no</TD></TR></TABLE>
I had the same exact problem with my ls/vtec at first. 310's cleared that right up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mishima_beef &raquo;</TD></TR><TR><TD CLASS="quote">I hear high revs kill ls/vtecs and b20/vtecs</TD></TR></TABLE>
You heard wrong
Old Sep 10, 2003 | 10:22 PM
Miles85916's Avatar
ever think about getting a Holley Fuel pump ? thats what my friend is running on his b20setup and what head are you using ? if its the b16 there will be no power, you will need to get the GSR head for better flowing.
try this new fuel pump
Holley Fuel Pumps
Old Sep 10, 2003 | 10:27 PM
blackANESE's Avatar
Default Re: PROJECT b20/vtec motor done, in car, running...but.... (Miles85916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miles85916 &raquo;</TD></TR><TR><TD CLASS="quote"> if its the b16 there will be no power</TD></TR></TABLE>
LMAO, please elaborate on this one. Your title fits you perfect.
Old Sep 10, 2003 | 10:41 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miles85916 &raquo;</TD></TR><TR><TD CLASS="quote">ever think about getting a Holley Fuel pump ? thats what my friend is running on his b20setup and what head are you using ? if its the b16 there will be no power, you will need to get the GSR head for better flowing.
Holley Fuel Pumps
I disagree. The B16 head on a B20block, especially high compression, has proven itself a good combo.
Old Sep 10, 2003 | 10:44 PM
racecarpete's Avatar
b16 head no power?
bwwaha ha ha. that's funny. I would also like to hear your reasoning. The b16 head and gsr head flow almost exactly the same.
Old Sep 10, 2003 | 11:51 PM
str8sleeper's Avatar
are you running stock internals?
cuz im bout to do the same thing on my b20 setup but instead its already turbo.
Old Sep 11, 2003 | 01:02 PM
Miles85916's Avatar
do you see anything up there on his post saying that he have High compression pistons ? no... with the GSR head it bumps the compression a little higher on the stock pistons.
