name the best 14:1 pistons for built motor
were can I buy the best 14:1 pistons? I dont want to have to have some custom made I want some one that already has them made. I will be running big nasty cams.
weisco ib spec is a good piston, and so its the endyne rollerwave, once you get up into that high of a compression there all going to be custom made, i think?
When you are talking that kind of compression I'm sure your going to have you compustion chambers polished, head milled, new valves, all sorts of stuff that could really throw off your originally intended comp ratios. Your going to need to get all your head work and mill work done, then send in the specs to someone to have them make your pisons...
It's really hard to get 14:1 with Endyn Rollerwaves...need to run almost zero deck and alot chopped off the head. Only 7.4cc Pistons...
IB Spec Super Dupers are 9cc tho, so it's alot easier...
Suprdave
Suprdave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">It's really hard to get 14:1 with Endyn Rollerwaves...need to run almost zero deck and alot chopped off the head. Only 7.4cc Pistons...
Suprdave</TD></TR></TABLE>
IB Spec Super Dupers!
That's what im using on my new motor, just in a custom lower compression ratio.
I was talking to larry over at endyn and I was told that with the roller waves and gsr head with stock chamber volume, that at 2.2 litre(my motor) that cr would be 15.24.1(dome volume 7.45cc)
yeah, but your motor is a 2.2..that's not we're talking about here. Your just using more stroke with the same piston to increase compression...
IThe motor will be a 85 mm bore with a ls crank so it should be about 2.1. I think I am going with the import builders.
i wouldnt worry so much about the displacement, as much as I would make sure that the rod stroke ratio is good. people get too caught up in the "I have a 2liter stroker" idea. Also, you might want to make sure your have proper valve clearance. With a big nasty cam, you have to be careful. Bad R/S ratio will kill your motor.
Louie
Louie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumbshit »</TD></TR><TR><TD CLASS="quote">IThe motor will be a 85 mm bore with a ls crank so it should be about 2.1. I think I am going with the import builders.</TD></TR></TABLE>
email me:
ibsales@importreview.com
Thanks,
Rod
email me:
Thanks,
Rod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumbshit »</TD></TR><TR><TD CLASS="quote">were can I buy the best 14:1 pistons? I dont want to have to have some custom made I want some one that already has them made. I will be running big nasty cams.</TD></TR></TABLE>
IB Spec SUPER DUPERS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec »</TD></TR><TR><TD CLASS="quote">where can i find IB Spec SUPER DUPERS pistons??
thanks</TD></TR></TABLE>
http://www.importbuilders.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rasman »</TD></TR><TR><TD CLASS="quote">
nice.....
so help the guy out and tell him what kind/brand they are.....
nice.....
those are nice pistons! hehe I know what kind fo pistons they are! very good design call jeff of IB he has I have seen them in a motor they are now I hear in a couple of motors around here! I'd tell ya but it wouldn't be as fun!
nice pic bro!
nice pic bro!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9redsi9 »</TD></TR><TR><TD CLASS="quote">
Yep</TD></TR></TABLE>Nope, Allmotorwhore got it right, IB Spec Super Duper Wisecos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow »</TD></TR><TR><TD CLASS="quote">
mess on some IB stuff</TD></TR></TABLE>
I don`t speak stunna, please translate.
