Corner light rewiring Q
I need a good wiring diagram in order 2 fix my driver side corner light on my 89 CRX si. I gotta get it fixed in order to pass safety inspection. The diagram in the haynes manual sucks.
the more detailed the better
LD EF8
89 CRX XSi
1gen Integ B16a
the more detailed the betterLD EF8
89 CRX XSi
1gen Integ B16a
what is it that you need exactly...do you need to find the wire that goes to the corner light? if so, get a wire tester and have fun.
robert
robert
i know what wire it is but its not getting power i need a wiring diagram 2 rewire it.
screw the damn volt meter thats takes to long a diagram would hell o alot quicker.
need to get this damn wiring done
safety inspect then perfectly leagal (kinda of
check here, they have the ef service manual and service manual supplement. hope this helps.
http://hybrid2.honda-perf.org/
na nothing. Anyone else know my car has been sitting way to long an i gatta fix this before i can drive around with out fear of gettin pulled over for something as small as a none working corner light and no safety inspection.
HELP!!!!!!!!!!!!!
HELP!!!!!!!!!!!!!
1 Cam Wonder
Nov 13, 2004 07:06 AM
